Question about Invicta Watches
What is the little "Button" looking thing on the 9 o'clock side of my Invicta Pro Diver Hydromax model #29726
Posted by richard sussan on
5 Related Answers
Anonymous
SOURCE: invicta pro diver strap length
ur supose to leave that one open and the rest u can tightin
Posted on Jun 16, 2008
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: how to remove links on invicta russian diver watch
Hi Pate the only thing i can advice you is go to a service center near to your place.All watch technician like me have the knowledge to remove the links with no impaired damage or scratch.We know how to detach the links.So if want to know more of your watch i will give you a site that can help you and ask more information about your watch. www.invictawatch.com
Posted on Jun 17, 2008
Anonymous
  • 4 Answers
SOURCE: DIFERENT DISPLAY FOR THE SAME WATCH MODEL.
A watch is considered Swiss, when it is made in Switzerland (hope I spelled that right), by a Swiss Comapny, using 50% or more parts that are also Swiss. Watches made this way will have "Swiss Made" Swiss" or a similar print on the back.
If it has the lables of "Swiss movement" "Swiss Case" then it means that it is only partly swiss made, and will not have a lable listed in the first part of this solution branded on the back.
Hope I helped, have a great day.
Posted on Jan 13, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Watch Froze
You have to change the battery. Battery was fitted in factory, not at the point of sale, so, it can be a few years old. Rate me, plz.
Posted on Mar 10, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: how to shorten my invicta (mens pro diver 8932)
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Aug 05, 2010
I want a link for invicta pro diver model 0886
https://www.invictawatch.com/watches/detail/0886-invicta-pro-diver-men-488mm-stainless-steel-stainless-steel-silver-dial-pc32a-quartz
Nov 11, 2016 | Invicta Watches
How to set?& manual required invicta.15343 pro dive
Invicta Pro Diver - View model
invictawatch.com/collections/view-model/15342-pro-diver
INVICTA COLLECTIONS click to view models · AKULA ... Instruction Manual Print. More models of the same style. 15343. Invicta Pro Diver · share watch. 15341.
Sep 25, 2015 | Watches
Invicta 8926A gains about 2 or 3 minutes after winding.
Send in for warranty repair with a description to Invicta
Oct 12, 2012 | Invicta Automatic Pro Diver 8926A Wrist...
The dial and spring on my Invicta 9937 Pro Diver are missing, Do you have replacement parts?
mcdevito75 here, Best Bet Contact shop NBC foer Invicta parts info, here"s their number, 800-474-6762 Hope this helps.
Aug 03, 2010 | Invicta Pro Diver 9937OB Watch for Men
Invicta pro diver 4469 under guarantee stopped working bought 10th July 2009 can i get this repaired in the UK with sending back to Florida thanks chris malone
I have looked too and can only find their Florida address.
This is unusual, as most makers have authorised dealers throughout the world.
Perhaps a local dealer may be able to locate an authorised repair agent.
Mar 15, 2010 | Watches
I have an invicta pro diver watch with stainless steel band. I need to buy 2 or 3 links and pins. Would a new band be better and where do I buy either item? Ilive in area code 75601, Longview, Texas. Thank...
I know of a couple places in San Antonio and Austin that would be able to custom fit your new band or help you with a repair.
Precision Time
They are located in the malls in either city. They also have a web site.
PrecisionTimeCo.com
You can try to contact Invicta for new links and they may have them depending on the age of the model. Look at your owners manual for contact information.
Sep 18, 2009 | Invicta Automatic Pro Diver 8926 Watch
How to set a invicta 3443 watch up
To set the time pull the crown out to the first position and set the time by turning the crown. Pull the crown out to the second position to set the date. Since this is a diver model you will need to unscrew the crown before it will pull out. Make sure you replace the crown and screw it back down for a good protective seal.
The alarm sets the same way. Unscrew the button to set.
Nov 24, 2008 | Invicta Pro Diver Collection Grand Diver...
Invicta pro diver strap length
Jun 10, 2008 | Invicta Pro Diver 9321 Wrist Watch
Watches Logo
181 people viewed this question
Top Invicta Watches Experts
Bruce Robin
ray gallant
Kardoc
Are you an Invicta Watch Expert? Answer questions, earn points and help others
