Question about Dehumidifiers
How do I order a new propeller fan (plastic) for model 0526011 Dehumidifier UPC # 8-40206-12002-3
Posted by norman anctil on
Tom Chichester
    Top Expert:
  • Dehumidifiers Master
  • 55,562 Answers
Contact the manufacturer/distributor to inquire.
Posted on May 10, 2019
Idylis dehumidifier 0526011 will not shut off even when is reaches it humidity level. How can I get it to shut off. The compressor stops but the fan keeps running.
this is a newer feature that a lot of units do now this is called air circulation mode !! try running on low it's not so noisy then
Oct 03, 2014 | Dehumidifiers
How do you set on and off auto
See page 7 on the user manual to set the humidity level and the unit will then operate within the set humidity range. You can also set the timer to make it shut off automatically after a specific time. You may also need to install the continuous drain feature if you do not want to empty the water tank repeatedly.
http://pdf.lowes.com/useandcareguides/840206120030_use.pdf
Aug 06, 2014 | Dehumidifiers
Idylis 0526011 does not work
SET IT TO LOWER SETTING
Mar 07, 2014 | Dehumidifiers
Need new squirrel cage fan for Maytag M7DH65B2A dehumidifier
Yes! I ordered one yesterday. Go to
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=281964&modelsID=115462&typeName=dehumidifier
or if that link doesn't work go to appliancefactory parts.com and search under Fedders dehumidifier parts.
Art
Jun 22, 2009 | Maytag M7DH65B2A Dehumidifier
Need a upc code for a DH304
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 18, 2009 | Goldstar DH304 Dehumidifier
Fan
For model M7DH45B2A Maytag 45 PINT Dehumidifiers
Parts for the unit. www.appliancefactoryparts.com
Part CRCFD5303-010 Fan - $19.99
Part CRCFD3000-030 Motor - $49.99
Parts for others are also available.
Sep 09, 2008 | Maytag M7DH45B2A Dehumidifier
Unbearable noise
Mine does the same thing, for the third time. Seems the plastic fan on mine, lasts a little over a year. Not hard to change, just a bad design on the part. I'm ordering an extra tis time, to save on freight.
Sep 05, 2008 | Fedders A7DH65B2A Dehumidifier
The fan fell apart on my M7DH45B2A and I was wondering how to find a part number for the fan to order a new one.
ApplianceFactoryparts.com has the replacement part for the "squirrel cage" for the motor or "fan". Use the Model number to find the parts.
Jul 10, 2008 | Maytag M7DH45B2A Dehumidifier
Doesn't want to stay on...
Most likely the fan motor has broken. Without the fan, the compressor will overheat. There is a safety device inside that automatically shuts off the compressor to keep the overheating from destroying it. Check to see if you can feel air movement in the front or back of the unit while it is running. If not, then the fan motor has definitely broke. I had this exact problem on mine.
If you take the unit apart, you will find a parts list inside the unit. It will be inside a small plastic pouch. You can order a new fan motor from Sears. The cost is $30 plus shipping.
You will have to move the condensing coil in the front out a bit in order to exchange the motors. Just be careful not to break any of the copper lines. They are copper so they will flex quite a bit without breaking. Still, use caution. If you break the lines, all the refrigerant will leak out and your unit will be useless.
Sep 01, 2007 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
119 people viewed this question
Top Dehumidifiers Experts
jasbo
jasbo
Marvin
Marvin
Are you a Dehumidifier Expert? Answer questions, earn points and help others
