Question about Blaupunkt Televison & Video
Trying to connect optinun romote to blaupunkt telly
Posted by Lesley Kelly on
Ihave just bought a 32" blaupunkt tv how do you get 6 months extra warranty
perhaps by going to their website and registering it . it certainly can not be done on FIXYA
Feb 14, 2017 | Blaupunkt Televison & Video
Pioneer how to install
Pioneer plasma pdp 436 xde cannot connect external speakers has telly no sound keff system surround we had packed up and now trying to connect some other speakers any help please
Jan 01, 2014 | Car Audio & Video
Message stating check signal cable
Hi there, This could be a few possible issues. What you can try depending on your setup, is 1st to try and connect your ps3 to a different telly using the same cables if possible, like if you had it connected to hd telly with hdmi cable, use this setup on another telly to see if you have the same problem. If it's the same on the 2nd telly then it's the hdmi cable that's the problem, just replace and you should be good to go, but if it works on the 2nd telly then you will have to adjust some settings usually a resolution issue on the 1st telly. You can also try using an analogue cable that came with the ps3 to see if that works. If it was the analogue cable you were using anyway you may need to get a new one, but try on another telly 1st to be sure. It's most likely just a resolution issue but if you have the same problem on 2 tellys it's probably the cable then. Hope this helps
Jan 22, 2011 | Sony Playstation 3 (PS3) Console
Video input
Hi the only slight chancer you have of doing this without the remote and this will only work with some tellys is to have the telly switched on then the device you have connected to the video input have this switched off at the wall then with the telly on switch the device on your trying to get the telly to pick up now some tellys will pick up the signal and go to that input channel, if how ever this dont work your going to need to go out and buy an all in 1 remote, these remotes cost next to nothing to buy you can get them off the well known auction site or from your nearest cheap shop such as discount stores that sell goods for next to nothing these remotes will work on all tellys and would solve your problem if the way i told you dont work.
Im sorry their is no easy way to get it to change but without the remote your pretty much stuck unless on the telly you have a button that looks like a square with an arrow running from left to right if you have this button then pressing this wil change the input source for you, if you dont have this then the only option would be an all 4 1 remote.
let me know how you get on or if you need further assistance ok
May 31, 2010 | RCA TruFlat 27F520T 27" TV
Hi, i have a ps one i want to connect to my tv via the aerial. iv plugged it in and checked the av channels but cant find it, is there anything i need to do?
Hi, right now as your plugging it in via the aerial socket then this means you wont be using any of the input channels or source channels such as av ok.
now what you can try is when its plugged in and switched on go through the channels on the telly using the telly remote try channels you dont use such as 0 6 7 8 9 10 if after trying these you still have no picture then you need to put the telly on a channel you dont use say 0 then make sure ps is switched on with a game in then on telly remote choose menu or setup then you need to use the tv setup function to search the frequency as if you are tuning a channel in so do this till you see the game then store it onto that channel, now when ever you want to play the ps you just plug it in and put it on the channel you tuned in.
or an easier option would be to go to the well known auction site and buy a ps1 scart lead then when you plug this into your telly you just choose av1 or av2 and then you can play it without tuning the channel in so this owuld be the easiest way
let me know if you have any problems
Feb 08, 2010 | Video Game Consoles & Games
I am trying to retune telly, sonys35u.at stage 8 it does not say antena
I am so sorry, Idid not know u had to pay for the service.from elder 84
Sep 22, 2009 | Sony Televison & Video
Romote program
There are a ton of codes for the Philips and Magnavox TVs. Your best option is to go here to find the codes:
http://remotefinder.rca.com/default.aspx?site=rca
The manual for the remote can be found here (as of 06/07/2009):
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Mar 16, 2009 | RCA RCR311B Remote Control
Connecting lead for Blaupunkt CDC-A03 changer
If you can find the installation instructions, you may be able to use individual spade connectors either male or female and connect direct.
BLAUPUNKT CDC A03 Operating And Installation Manual Page 9
Or try somewhere like Crutchfield
Blaupunkt CDC A03
Mar 02, 2018 | Blaupunkt CDC-A03 10-Disc CD Changer
Just bought a boat with Blaupunkt radio, never received the code - trying to decode.. Model#47001402 / B472601189
you will have to ask the orig owner for that code or send it into blaupunkt to have it reset
Aug 14, 2008 | Blaupunkt Car Audio & Video
Televison & Video Logo
19 people viewed this question
Top Blaupunkt Televison & Video Experts
Marvin
Marvin
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Blaupunkt Televison and Video Expert? Answer questions, earn points and help others
