Canon PIXMA MP600 all-In-One InkJet Printer Logo
Posted on Aug 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printing purple instead of black on photos
Any photo's printed have purple where black should be. This problem started recently and I have cleaned the printer heads. Black cartridges are full.
Anonymous
Level 3:
President:
  • Master 2,923 Answers
  • Posted on Aug 07, 2009
Anonymous
Master
Level 3:
President:
Answers
2923
Questions
0
Helped
730243
Points
8409
Did you recently buy the cartridge? What is the expiration date on the box? It may be old or not working well, just as you have guessed, and the printer is using the color cartridge to create black when the black does not function. If you have the option return the cartridge.
Printer will only print purple
on a colour printer, black is mixed with the other colours. Try printing a black and withe photo and you always get a colour cast. If your black cartridge is empty or the nozzles are blocked, you get bad colour and fussy prints.
test all nozzles, like is explained in the manual.
Check, if you know how to do, if nothing fell in the printer, that is now on the print head. Sometimes just dust or paper scraps are picked up by the printhead, making it difficult for the printer to print a normal page.
My hp printer casts purple to black and white prints
Tried your settings with no luck. Also tried every canon profile listed to no avail.
These are my settings:
Color management:
Color handling: Photoshop manages colors
Source space: sRGB...2.1
Printer profile: Canon MP620 Series GL2/52G
Rendering: Perpectual
Media Type: Glossy Photo paper
Print quality: standard
Effects: borderless
Printer Preferences:
Color Intensity: manual-set-everything is 0-matching:none
I am using Kodak glossy paper and I am using that setting. I am printing a digital scrapbook page with color. I used black and white pictures in the page trying to get rid of the purple trees, so it shouldn't be printing any color at all in the photos, but the limbs are still purple.
Under color settings in PSE I have checked "optimize for printing".
I am off to the store to pick up another package of photo paper..maybe HP or Epson will be better (I think those are the other 2 choices in the store)
Will check back in after I try the other papers
Aftermarket car headlights
3helpful
2answers
Canon i9100: colors printing incorrectly
I've had the Canon i9100 since 2003 and have excellent photo printing results. In 2009 it started playing up and I'd gt some banding. More recently, black didn't want to print. It was as though the black ink in the print head got dry some days.
April 2010 - The colours started printing strange and I bought a brand new print head and installed it. Only takes a minute. Still had an issue with photo printing. Black and white was excellent but colours weren't true.
Found advice online to try cleaning the print head to print head carrier electrical contacts by rubbing them with a rubber eraser.
I did that and now I'm getting perfect colour photo prints again.
I had been thinking about buying a new A3+ printer but this is old printer is now working as good as new.
Was printing photos all was ok then printer stoped printing black
There are 4 inks, cyan, magenta, yellow, and black. When the black runs out, you are left with sort of a dark purple or brown color.
1helpful
Canon S520 printer colours not correct
i think its time you replace/refill that ink cartridge. some of the colors must have run out.
4helpful
3answers
Prints purple instead of black on photos only
My Canon printer has TWO slots for black ink cartridges. I assumed one was extra and didn't replace it when I ran out. Text printed just fine with only one installed, but my photos were printing with purple instead of black. I looked into it, and the two cartridges are different: one holds dye-based ink, the other has pigment based. Photos must require both kinds. If your printer is the same as mine, use both!
2helpful
HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
16helpful
2answers
Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
2answers
C88 printing purple instead of gray
check and make sure the cartridges arent faulty and that the ink color matches
old marine
old marine
ZJ Limited
ZJ Limited
