Question about Hotpoint Ultima WF860 Front Load Washer
I have washing machine Aquarius wf640 + it keeps showing f-02
I have just put the belt back on + it worked twice but on some programmes it keeps showing the code f-02. Does anyone have any idea what it is. Thank you x
Posted by sharon_odonn on
  • Susanewman
    Susanewman Nov 24, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
Barry Coates
  • Hotpoint Master
  • 3,463 Answers
F02 indicates that the motor tacho has broken or become detached, this is to be found on the end of the motor shaft.
Pleawse rate my solution.
Thanks.
Posted on Aug 07, 2009
Zachery Keith
My hotpoint Aquarius wf640 washer belt keeps coming of
Posted on Nov 23, 2021
Hotpoint aquarius washing machine displaying tESt +won't do anything
Someone has accidentally pressed some buttons and locked you into test mode.
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work.
The machine keeps showing test. it won't go onto any other programme. it keeps running through the test programme then stops, i then try and put it to wash and it will come up with test again.
http://appliancejunk.com/ge/washer/31-9103.pdf OK, to help you, I have found you your service and troubleshooting manual. Below is a DIY self help. washer link, this will help you to troubleshoot your issue. http://www.acmehowto.com/howto/appliance/washer/washer.php
You should try to reset it, but if that doesn't work, you may find you have a main controller board failure.
1helpful
2answers
H20 ERROR SPIN DRYING
The error indicates a problem with the incoming water supply.
Check for restricted or kinked inlet hose/s, check that tap/s are fully turned on and that you have adequate water pressure.
15helpful
Test light
Press and hold "on/off" and "start" buttons together for five seconds.
Crease reduction facility won't work
Crease reduction facility is just a slower spin cycle if you coose a delicate wash there will be no apparent difference
28helpful
2answers
Wf640 test
This has happend to me today! this is the fix
  1. Press and hold the Start/Cancel button until message clears
  2. Now press both Start/Cancel and On/Off buttons together until you get a dOFF message
  3. now your machine should work OK
3helpful
Hotpoint Aquarius WF640
check your water supply to the machine is of adequate pressure . this is the sign when the machine is not getting enough water
Hotpoint Ultima WF860 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
Paul Carew
Vernon Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
