Question about LG KM900 Arena Cell Phone
My phone isnt showing names when people ring me or text me.
Posted by paul_francis on
Anonymous
    Sniper:
  • 78 Answers
Sync your phone with Outlook
make sure it has copied all the contacts over to the PC.
Delete all contacts in the phone
Connect phone to PC via PC Sync
Press the Sync button in PC Suite
Click on settings and change the 'contacts' to 'phone only'
Then sync
Posted on Aug 09, 2009
Anonymous
  • 265 Answers
There must be duplicate contacts. that is two names for same number..
Posted on Aug 07, 2009
My phone basically just started losing applications, when i went to text it isnt showing that i have any conversations, which i know i do, and when i hit the cross to add a conversation it freezes for a...
That shows the memory of your phone is full so try and decongest some information on your phone that you feel you don't need again to create space for you to be able to do some other things on your phone.
Feb 09, 2011 | HTC 7 Surround Cell Phone
Dosnt show any words
If your phone refuses to show any word, there seem to be a software problem with the phone.
All you have to do is to get the appropriate software and cables, then flash the phone.
It will work perfectly once again.
Take care
Jun 14, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Is there a way to stop your phone from saying the name of the person that is calling or texting you?
Hi The way to stop this is go to voice commands, settings, and one option should say call alert, and you can set it to ring only, caller ID+ring, or name repeat, and set it to ring only. Hope this helps, Joe
Feb 18, 2010 | LG VOYAGER VX10000 Cellular Phone
SMS - Recieve number instead of Name
When it comes through it usually comes with the area code and number correct? that is the way you have to save it. Look at the number and if it has the 1+ area code+ number that is the way the phone rconises it and that is the way it needs to be saved. I always save mine to phone instead of the sim since it gives you more options in the phonebook.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact [email protected] Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
May 01, 2009 | Dual Electronics N99i Cellular Phone
E63 - contact names do not appear next to text messages in inbox
No duplicates in there if there is more than one number attached to more than one name the nokia refuses to show caller name, cheak phonebook to make sure there is one number to one name only
Apr 16, 2009 | Nokia E63 Cell Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
When a new text or call is says Message/Phone call from....."
Go into phone settings, then voice commands, then call alert. Set it for ring only. I have the EnV2, so it could be a little different, but thats how i do it on my phone. Good luck.
Jan 29, 2009 | LG enV VX9900 Cellular Phone
Recieving calls
when u have the name stored both in phone memory as well as sim memory this happens. try removing any one.
Nov 01, 2007 | Nokia N95 Cellular Phone
LG KM900 Arena  Cell Phone Logo
179 people viewed this question
Top LG Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Sheldon Dedek
Daniel Dollive
Daniel Dollive
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
