Question about LG Refrigerators
LG 30 InstaView Refrigerator with Door-in-Door freezer not working
Freezer was working fine but now everything is dethawing. Temperature setting is good but it's not freezing.
Posted by Gabrielle on
5 Related Answers
Anonymous
  • 66 Answers
SOURCE: The Freezer freezes...and so does the Refrigerator!
your thromstae is bad
Posted on Feb 06, 2008
Anonymous
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
Anonymous
SOURCE: Samsung double door refrigerator/freezer is not
I just had (have?) this same problem. I called out the repair man and in the end he suggested that I buy a new fridge because of all the problems reported with my model (RS2555SL) on the internet. Anyway, after a while I heard what sounded like a fan trying to spin on the fridge side. I unplugged the unit, removed the inside back panel on the fridge side. The entire coils and the fan had iced over. I removed all the ice, plugged the unit back in and it is now working. I will still replace this unit because I probably only corrected the symptom but the problem remains.
Posted on Jun 21, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: FREEZER TOO COLD - REFRIGERATOR TOO WARM
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
aasc
Mike Smith
  • 1606 Answers
SOURCE: Refrigerator is cold, freezer not freezing
Amana refrig have 2 main problems . 1 is the defrost bimetal ( 1" cylinder at the top right on the freezer coils with 2 wires ) and the other is a refrigerant leak where the copper tubing joins the aluminum tubing at the freezer coils ( evaporator coils ) . If your freezer fan is not working and you have frost on the freezer coils then replace the bimetal as this also controls the defrost heater ( defrost thermostat ) . If you have no frost on the coils ( for both checks , you will have to remove the inside rear freezer panel , maybe 12 screws ) , then a refrigerant leak has happened and the best solution would be to replace the refrig .
Posted on Jul 18, 2010
My LG window AC icing on the grid even in fan mode. Once started it gets covered with ice within 1 hours in both cooling as well as fan mode? What can be the reaon
First, I'm not a LG tech.
Check your warranty and call for service.
*** Following is for information only.***
* Check for air movement while fan is running. Many have plastic ducting that pulls air from the bottom that is usually covered by the lower drawer. Pull out the lowest tray and check the back for ice or food that fell in back to block the air vent. If it's iced up, DON'T hit it as you will crack the plastic. Leave the door open, Turn off and let the freezer defrost. (remove food).
* Check the upper fan vent for ice blockage. Defrost as needed.
* Unplug refrigerator to defrost. (Get help to move as the fridge is heavy and may tip over on you.)
* Once completely free of ice (it takes a while. A fan blowing into the freezer helps. ***DONOT use a heater!*** Warps panels and may over pressurize refrigerant.)
* Allow a completed defrosting of the freezer. (Place frozen foods in refrigerator side to keep it cold while the refrigerator is off. Better to transfer everything to another refrigerator.)
* Keep checking and dumping the drain tray as the ice melts. If no water drains then the line may be clogged. Call for service.
* Plug in refrigerator but leave out where you still can unplug it if you need to continue to defrost. Move it back only if everything is working (so far).
* Set the temperature to middle of dial and the freezer diverter to normal (middle). Leave fridge empty to allow it to cool down without a load. Check for icing (there shouldn't be any as there is no moisture in box to ice up.) If there is ice then it did not defrost enough. Turn off and repeat manual defrost (open door)
* Once your sure all the ice is gone and the freezer is cold. Move refrigerator back into the counter/wall. (it's lighter but get help anyway.) Start putting back the frozen goods. Try not to cram in everything. Keep enough space on racks to allow air flow AROUND the whole shelf. Keep away from leaning food against the walls and back.
* Leave the temperature setting at mid range. Your refrigerator should be able to keep food frozen at this setting.
* Check your door seals for cracks
* Check your door perimeter for warmth. It should not be sweating or ice cold. Cool or slightly warm to the touch is normal.
* Check your side panels (not doors). It should be cool but not iced or sweating.
* Final, with the Temperature set at mid range. If your still getting ice then you have a vapor leak. (Moist air getting into the freezer) Note that this moisture can also come from hot moist food placed in freezer without pre-chilling it. If you must put hot food In the freezer. Then place it in the refrigerator section for at least an hour prior to the freezer. The refrigerator can handle the moisture load better than the freezer. The refrigerator just collects the water and drains it to the bottom pan.
* Again, check your warranty and call for service. Have them perform yearly maintenance to check everything.
Aloha, ukeboy57
PS; If everything is okay (so far) then only gradually adjust the temperature SLOWLY. You will find that maxing to the coldest setting will only build up the ice quicker. Normal freezer operation can take care of the occasional (daily) opening of the freezer door. It will 'dry' out the frost and ice build up (If given the chance). But if you find that Ice keeps building then you need a bigger new ice box.
Feb 21, 2018 | LG Refrigerators
I have two door bottom freezer in my LG refrigerator...Freezer is defrosting its' contents..I lowered the temperature but it still persists...any solutions?
My bottom freezer LG is intermittently shutting down and thawing everything in the freezer (cooling stops in fridge part, too). $3,500 for a refrigerator that works only 18 months.
Mar 18, 2013 | LG Refrigerators
Dethaws every 2nd or 3rd day open freezer door push door switch and works fine for an other couple off days this has been happening for about 1 week or so
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 29, 2011 | GE Refrigerators
FREEZER WORKING BUT FRIDGE NOT
Remove the rear panel in the freezer and see if the evaporator coils are frozen over.
If so dethaw coils with a hair dryer.
Reassemble freezer and set controls to the normal position.
Although you replaced the defrost timer if the coils were frozen over in the freezer no air can transfer to the ref. section from the freezer.
If you do not want to dethaw the coils unplug the ref. for 1-2 days and leave the doors open .The coils will dethaw by then.
Jan 17, 2010 | Kenmore Refrigerators
LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
Jul 26, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Freezer dethawed
By the end of the day we realized we thought the refrig. part was working but was not. We pulled it out from the wall, unplugged and plugged it back in. Still no results. I unloaded everything from the freezer in the morning and refrig in the evening. Right after I got almost the very last item out, (the door on the refrig was opened and left opened) I moved the temperature control levers back and forth quickly, really just out of frustration, thinking, 'great no more refirgerator' - now what am I gonna do?!. i went to dump the last of the contents, and like some sick joke, the refrig started working and then the freezer. We have quite a bit of dust under the refrig. that may have been blocking a fan or something. I think God just wanted me to empty the refig contents and things that looks like pieces of the moon from my ridge. Go figure. I am praying no more problems.
Jun 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool refridgerator issue
clear ice,clear drain, all the way to the drip pan, and tilt unit slightly to the rear
Apr 22, 2008 | LG LFC25760 French Door Refrigerator
Refrigerators Logo
64 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
