Question about Golf
Can't get gas in the carb. on a yonghe go cart
Posted by Gene Denney on
Kardoc
    Top Expert:
  • Golf Master
  • 6,119 Answers
Check to see if the carb is gravity fed or has a fuel pump. If it gravity fed then trace the line back to the tank checking for an obstruction. Make sure there is no obstruction in the tank. Flush the tank and lines. If it has a fuel pump, make sure it is working properly. If fuel is at the carb. then you may have to clean the carb and adjust the float.
Posted on May 09, 2019
Yamaha golf cart 1996 ulima g14ap engine jn3 200191 start but wont stay running put a new fuel pump on still wont stay running y
Have you cleaned the carb? Many times if they sit up with this ethenal gas it eats the seats an causes a gell to form in the carb bowl. I would check an clean carb first with new gas.
Jun 01, 2017 | Golf
Yamaha golf cart gas will only run when spray starting fluid in carb
Most likely carb bowl is dirty and /or float needle valve is clogged. Clean them and use only fresh gas afterwards. Also check filter.
Apr 11, 2017 | Yamaha Motorcycles
I have club car golf cart. I get to start,later it won't start,looks like no gas is coming in to carb
if is is fuel problem check the fuel filter and or carb needs to be repaired or replaced possible debris or float valve sticking
Sep 13, 2016 | Golf
Need a manual for my 1990ezgo golf cart free printable please showing pictures of the carb and filter and gas lines
Visit the on-line store, know as reliable-store, they have the repair, parts and operating manuals. I'm sure you will get the solution of your problem.
ezgo golf
Jul 18, 2016 | Cars & Trucks
My gas powered gulf cart will start and crank when i push on the gas but will not go. What would cause that?
Hi sounds like a blocked main jet in the carby if it's running on petrol..cheers
Apr 26, 2016 | Golf
My golf cart has to crank more than necessary before engine starts. Choke does not seem to make a difference.
The carb choke circuit is most likely plugged which is why it has slow starting. The clunk may be from the engine idle being set to high. It probably is running high idle because it has carb issues and the fuel system may need cleaning.
Oct 14, 2015 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
Replaced fuel pump on golf cart, not getting full power to move cart forward or back
If the Cart sat for months, I would bet the ethanol gas gummed up your carb. Ethanol gas.... What are our politicians thinking????
Sep 08, 2015 | Cars & Trucks
Motor runs but cart won't go
1 check and clean fuel tank and lines
2 clear air filter, soapy water air dry then apply any air cleaner oil
3 adjust carb / chock
4 check for proper spark replace plug (2.99 )
5 make sure drive belt in good working order.
odds are the carb chock should fix you right up
May 23, 2014 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
Tomberlin crossfire 150 parts
put a bottle of sea foam in it -otherwise carb needle valve stuck shut or fuel pump not pumping- Denny
Dec 31, 2013 | Cars & Trucks
I have a 1984 ez-go gas golf cart it won't run unless you take the gas line off and squrit gas direct into the carburator throat what is the problem
remove your carb. and thouroughly clean it, remove diaphrams/needle and give it a good clean and rebuilt job.
Feb 14, 2012 | Cars & Trucks
Golf Logo
154 people viewed this question
Top Golf Experts
ray gallant
Kardoc
Tom Chichester
Are you a Golf Expert? Answer questions, earn points and help others
