Question about Homelite Garden
Have a Homelite XL-98C multi purpose saw Ut # 050158 and serial # HI2430319. What is the fuel mixture ratio?
Posted by Rose Aumick on
Jim
    Scholar:
  • 158 Answers
16 to 1 There is a universal synthetic oil that works well for most all 2 cycle engines and causes less problems than standard 2 cycle oil. Also try rec 90 or rec 89 gasoline it contains no alcohol and will stay stable longer.
Posted on May 10, 2019
3 Related Answers
Anonymous
  • 583 Answers
SOURCE: Homelite Textron chain saw UT 10403A ...need
25to 1 and .025 thou
Posted on Aug 06, 2009
Anonymous
  • 333 Answers
SOURCE: what is the fuel mixture ratio for a homelite XL
50:1
Posted on Oct 17, 2009
dontbother10
dontbother10
  • 2220 Answers
SOURCE: I have a 1979 Homelite XL Chainsaw model # UT
32:1 according to this.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/57a3b86d6acae4e188256c260048b728?OpenDocument
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 14, 2010
Fuel ratio for homelite ut104444
The recommended 50-to-1 fuel mixture includes 2.6 ounces of a high-quality, two-cycle oil with added fuel stabilizers and 1 gallon of unleaded 87-octane gas. Homelite recommends using their brand of oils, specifically designed to work in any model with a 50-to-1 fuel ratio.
Homelite XL Textron Fuel Ratio ' Home Guides ' SF Gate
homeguides.sfgate.com/homelite-xl-textron-fuel-ratio-89880.html
May 13, 2018 | Homelite Garden
I need any info on a 20 in homelite super xl automatic ut#10045c.such as year made, fuel mixture, how many cc'so it is. All information that I can get will be great
I bought up a lot of Homelite parts when dealer went out of business about 20 years ago and have had interest in them since. I have worked on a few super xl's but cannot tell you for sure the fuel mixture but believe it probably changes over the years from 16-1 to 20-1 saw on internet one person claimed that that ut number used 32-1. Don't believe it would make any difference as long as you used good grade 2 cycle oil and it would not smoke near as bad as 16-1. One person on internet claimed that he still had the saw his Dad bought new in 1967 or 68 so they have been around that long but at that time I do not believe they had a UT number on them.
The cc is 57.4 and weighs 13.14 lbs. With 24" bar.
Sep 02, 2017 | Homelite Garden
Homlite string trimmer sx-135 ut-20609 a ratio gas & oil mixture
You should mix 8 Oz. of two cycle oil to one gallon of gas. I put the oil in first and then the gas and it will be mixed and ready to go.
Jun 08, 2016 | Homelite Garden
Homelite xl-98c will not start
Changing a spark plug rarely fixes a no start problem. You need to troubleshoot the saw more. Do a search on youtube or google about how to check for spark and how to check to see that the carburetor is getting fuel.
Feb 24, 2014 | Homelite Xl-98a, Xl-98c, Xl98-d, Xl98-e...
XL UT # 10655A Serial # HL1490086 XL 2 Serial # 40152376 Recently bought these 2 saws and have gotten 3 answers for the gas/oil mix. Can you tell me what is the right mix??
Run what ever fuel/oil mix you are comfortable with. A run lean condition is most often caused by an undetected air leak leaning out the mixture to failure. A couple of ounces of 2-cycle oil will not prevent its occurrence. If an owners manual (OM - I tried) is ever located it likely says 32:1. Most modern saws recommend 50:1:
Oil Mix Ratio:
In the early to mid 90s Dolmar, Echo, efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear
Sep 18, 2010 | Homelite Garden
Do not know what mixture or how to use
40:1 mixture for the fuel:oil ratio.16:1 will cause your saw to barely run(if at all) and if it does, will fog out every mosquito for 4 blocks. You can use any reputable 2-stroke oil, though stay away from outboard engine oil. Get the good stuff that says Stihl, or Husquavarnah, or something like that. Even the Homelite stuff is ok. The oil tank takes regular bar and chain oil.
May 30, 2010 | Homelite ZR10926 16 Chain Saw
Gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
May 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Fuel Ratio
40:1 is about right. Be sure to use modern synthetic oils made for saws and premix thoroughly before adding to the saw.
May 04, 2010 | Homelite ZR10926 16" Chain Saw
I have a 1979 Homelite XL Chainsaw model # UT 10045C Serial # 3E1930093. What is the fuel mix ratio for this saw?
Lou
Apr 14, 2010 | Homelite Garden
Chainsaw gas mixture ratio
An XL from that time frame recommends 32:1 here:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/d4b1071a456ca76c88256cd6001cc24c?OpenDocument
If my saw it would be adjusted for and operate on 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 27, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
Top Homelite Garden Experts
bryan st
Randy Schumann
Randy Schumann
colesmowers
Are you a Homelite Garden Expert? Answer questions, earn points and help others
