Plumbing Logo
Question about Delta Plumbing
Delta touchless faucet turns on just fine, but there is a several seconds delay when I turn it off. I did replace the batteries
Posted by Suzanne Wilson on
Kevin K.
    Sergeant:
  • 251 Answers
Open the battery case and realign the batteries with the positive and negative poles in the right positions according to the layout in the battery compartment. Close the battery compartment. Make sure it locks completely before continuing.
Locate the reset button, if any, on or near the battery compartment, after changing out batteries.
Push the red reset button to reset the faucet.
Test the faucet to ensure the reset corrected the problem.
Tip
Not all automatic faucets have red reset buttons. Some faucets just require inserting new batteries or realigning the batteries in the compartment to complete a reset. on the faucet. Check the instructions that came with your automatic faucet or locate the user's guide online at the manufacturer's website.
Posted on May 08, 2019
Testimonial: "This is a TOUCHLESS faucet--your answer was for a touch facet."
Why does touchless water faucet only work when other faucet turned on?
It's possible that the solenoid valve in the touchless faucet is not functioning properly, and needs to be replaced. Another possibility is that there is a loose or broken wire in the electrical circuit that powers the solenoid valve. You may want to check the connections and wiring, and consult a plumber or electrician if necessary, to help diagnose and repair the issue.
Oct 18, 2021 • Plumbing
I have Delta touchless faucet that will not turn on when you touch it. Changed batteries and there is no blue or red light
My recommendation is to reset the LED light wire and battery pack. To do this, disconnect the LED light wire from the solenoid. Disconnect the battery pack and wait a full minute. While you are waiting a full minute, you can check batteries to see if they are in good condition, even try new batteries. Make sure all batteries are in the correct direction and are tightly secured in the battery pack. After a full minute, reconnect the LED light wire into the solenoid and then reconnect the battery pack. Wait another full minute. After the full minute, you can then check your faucet and see if the lights work . If this procedure does not fix your issue, contact Delta Customer Service at (800)345-3358 Monday-Friday, 7am-7pm, CST and Saturday, 8am-5pm, CST. You may also email them at [email protected]
3answers
How can choose a touchless kitchen faucet?
The market is full of brands making these faucets but how to decide which one is the best suited to your needs. Below mentioned are few things which should be kept in mind while making a purchase of a touchless kitchen faucets.
  • Position of the motion sensor
    It is important to check where the sensor is placed on your kitchen faucet. Their position varies from brand to brand. Some of them come with the sensor installed on their spout, while others have them at the bottom or the top of the faucet. It is up to you to select the one which suits your needs. Moen touchless faucets have two sensors, and the wave sensor is placed at the top which is responsible for the activation and deactivation of water flow and the other sensor, ready sensor is placed at the bottom, which is used merely for identifying the articles in your sink.
  • Power Source
    When it comes to a power source, there are two types of touchless kitchen faucets in the market. For the ones that need a continuous power supply you have to make sure that they are installed near a power outlet in your kitchen. The other type runs on a battery and can be placed anywhere. You can choose either depending upon your kitchen needs.
  • Others
    Before buying the faucet for your kitchen make sure its length, height, etc. is appropriate for your kitchen. Also make sure whether it is easily installable or not.
Mar 19, 2018 • Plumbing
I have a delta touch faucet and the blue led light stopped working. The red is still lighting and the touch feature is working properly. How can I fix the blue led light?
  • Solid Blue - Normal operation, "Touch" mode is activated.
  • Flashing Blue - Normal operation, the hands-free mode is activated.
  • Solid Red - Warning mode - Replace batteries as soon as possible. While the water is running Solid Red LED is illuminated. When the water is off, the Red LED flashes once every 5 seconds. The faucet operates normally, solenoid valve is open.
  • Rapid Flash Red - Alert Mode - Battery Failure Imminent. The Red LED flashes once a second. The first time the faucet is used, the Red LED will turn ON, the solenoid valve will be opened and remain open. The manual valve must be used until the batteries are replaced.
  • Solid Red - Lockdown Mode - Replace Batteries. Extremely Low Batteries - The RED LED is ON, and water will not flow. The solenoid valve is closed and faucet will not operate until batteries are replaced.
  • Long Flash Red (2 seconds on / 2 seconds off) - Board error, replace electronics kit, RP53230 See manual bypass of electronics section of Installation instructions.
Why does my Delta faucet have a major delay when turning it off by touch
Delta has a toll free number to call but have your model number ready when you call
I want a faucet that shuts itself off (saves h2o).
search for "touch faucet" (Delta and Kohler have a few) or search for touchless faucets (many manufacturers have these with a sensor like at public restrooms)
May 07, 2010 • Home
Kitchen faucet won't turn all the way off
You need to replace the washer on the stem. It's a Delta so it's possible that you have the type where the washer is actually in the very bottom of the manifold instead of on the stem.
Water delay when turned on-when turn off runs a few seconds
there may be an air lock in your water pipes causing pressure at the end, as daft as it sounds try bleeding your radiaors as that worked for me...hope this helps ;-)
2helpful
Sprayer loosing presure
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Top Delta Plumbing Experts
David Shaub
john h
Mike
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
