Question about Pool & Spa
My temperature reading on my Spa Berry is rolling right to left like a slot machine. I have unplugged it and restated it with the same result?
Posted by Terry Piche on
My Vegas hot tub keeps showing eo3 can you give me some advice please
looks like it's got a bad thermister or thermostat
E03 The pump's thermometer reads the water temperature below 4°C (40°F)
1. The water temperature is lower than 4°C (40°F).1. The spa is not designed to operate with water temperatures lower than 4?C (40°F). Please unplug the pump and move to a warmer ambient temperature. The pump should only be restarted when the water temperature reaches 6°C (43°F).
» 2. The pump's thermometer is broken.
Hot Tub Ireland
Feb 24, 2018 | Pool & Spa
Lazy-spa hot tub saysE03 what to do
E.0.3. The pump’s thermometer reads the water temperature below 4°C (40°F)
1. The water temperature is lower than 4°C (40°F). 1. The spa is not designed to operate with water temperatures lower than 4?C (40°F). Please unplug the pump and move to a warmer ambient temperature. The pump should only be restarted when the water temperature reaches 6°C (43°F).
Dec 28, 2016 | Pool & Spa
Is it normal for a Cuetec R360 shaft to show some warpage when rolled on a pool table from brand new? I have gotten two so far and they are both warped. It doesn't seem right to me.
a new cue should not be warped, especially one that you pay good money for.
this is from their web site:
Cuetec's composite cladding of either graphite or fiberglass completely encases the solid wood core in an armor of high-tech synthetic material. This "Power Bonding Process" protects the cue from warping by locking out moisture and temperature changes.
Jan 13, 2015 | Pool & Spa
New heater was left dry for 4 weeks while spa pump was replaced. turned back on with error code Fault-shorted H20 Sensor. is it truly in need of replacement or can it be cleaned after sitting and rusting?
You can put an ohm meter on the two wires of the temp sensor and see how much resistance you get. I can't find the chart right now but you should read about 15,000 ohms at a water temp of 88 degrees. Resistance drops as temp rises. A "short" will give you the same result as just holding the two test leads together.
Having the heater idle for a few weeks should not have affected anything. The temp sensor isn't too hard to change yourself if needed.
Sep 15, 2013 | Jandy Lxi Heater Temperature Sensor...
When the labtob get restat dose not com up untill push f2 and then push escape
Remove all media, DVD, CD, USB, etc., unplug, remove battery, plug in , try to reboot normally. If it fails boot and open/run MSCONFIG, by typing MSCONFIG in the RUN box, select in the General tab, Normal Startup, click Apply, reboot machine. Post results. Or try a System Restore/Recovery.
Apr 15, 2013 | HP Pavilion dv6000z Notebook
Can you tell me how to thread a Graphic III laminator?
5-2 THREADING the LAMINATOR
1. Remove the supply roll mandrels and the feed tray. The supply roll mandrels are now ready to accept
loading of the film rolls, wound with the polyester (shiny) side out. When viewed from the front of the
machine, the core grippers on both the top and bottom supply roll mandrels should point toward the
heat shoes (and toward each other). The tension control knobs should be positioned on the right. Notice the
knobs are labeled "Top Right" and "Bottom Right". If you have rolls of film on which the material is wound
in the opposite direction (adhesive or dull side out) exchange the top and bottom supply roll mandrels so
the core gripper positions are reversed.
2. Slide a roll of film onto the top supply roll mandrel, turning the roll slightly to slide the gripper inside the
core. Center the roll. Make sure the dull side of the film is facing up and the shiny side is facing the
heat shoes during the threading. Scored marks on the supply roll mandrels provide a guide for proper
alignment of the two rolls of film to each other.
NOTE: The pointed metal pieces protruding from the body of the supply roll mandrels grip the cardboard core of the film supply roll to prevent slippage. When placing a roll of film on the mandrel, twist the film supply roll to
accommodate easier film loading.
3. With the roll aligned with the scored line on the right side of the mandrel, place it in the top bracket.
Place the left side of the shaft in its slot first then place the right side of the shaft in its slot, turning it as
needed. FOLLOW THE RECOMMENDED LOADING PROCEDURES CAREFULLY WHEN THREADING
FILM IN THE LAMINATOR. ACCURATE ALIGNMENT OF ROLLS WILL MINIMIZE WASTE AND HELP KEEP
THE LAMINATOR CLEAN.
4. While the machine is still cold, review the threading diagram. With the bottom roll of film centered on
the mandrel and the shiny side facing down, run the film under the bottom idler bar and pull towards
you.
5. Load and thread the top roll of film in the same manner as the bottom roll. Refer to the threading diagram. The
film should run under the silver stabilizer bar and over the front of the top heat shoe. Remember, the shiny
side of the film must always go against the shoe. The dull (adhesive) side must face away from the shoe.
Make sure the two rolls are aligned with each other before going to the next step.
6. Turn machine on and heat to the desired temperature.
7. With both rolls threaded and installed in their respective brackets, unwind enough film from the top roll
to reach the bottom of the bottom heat shoe. Next, unwind enough film from the bottom roll to reach the
top of the top heat shoe.
8. Now drape the film from the bottom roll against the film from the top roll on the top shoe. If the laminator is
hot, the exposed adhesive on the top web will hold the bottom web and make it easy to stick the two rolls
together. If you are threading the machine while it is cold, use tape to stick the bottom web against the top
web.
9. Tip the safety shield down into the laminating position. With the film draped over the two heat shoes, push
one edge of the threading card between the heat shoes so that the film is firmly positioned against the
laminating rollers. If a threading card is not available, any piece of card stock or poster board will work.
10. Make sure there is still enough slack in the web. Turn the drive switch to FORWARD, permitting the film and
feed board to pass through both sets of rubber rollers. Carefully monitor initial threading to be sure the web
reaches and passes through the pull (back) rollers. When the threading card has cleared the back of the
machine, move the drive switch to the center position (off). Whenever you want to remove the film and/or
laminated material from the back of the machine, use the zippy cutting tool provided with the laminator.
11. Slide the feed tray into position.
12. If the machine has the slitter option, make sure the slitters are disengaged (blades in the raise
position) and moved all the way to either side of the machine.
CAUTION: The laminator is designed to be run with the operator directly facing the
control panel and feed tray, not at an angle or from the side of the machine. For
operator safety, the safety shield must be in position over the upper heat shoe
when the machine is ON, or when the drive switch is in the forward position.
Dec 21, 2010 | Office Equipment & Supplies
Gladiator Model No. XXRK- Freezer door was left ajar overnight a little while ago - Now I cannot get the temperature back to zero. I cleaned a blanket of dust off condensor coil- no change... Not Always-...
Gladiators are a unique breed from any other style of refrigerator for their convertible capabilities of altering which section you wish to be the fresh food or the freezer, and the ability to use it in colder ambient temperatures than a typical residential refrigerator. This unique capability requires the use of a reversible fan motor and and dampers as well as additional foam insulation. If the door was left open, you have likely a buildup of frost and or ice in these air ducts as a result. My advice, empty it out, unplug it, open BOTH doors, blow a fan into the cabinet for a minimum of 24 hours. The water coming from the suction line of the compressor could be a sign that there is a little too much refrigerant in the system, or that it is in a fairly warm area, or near some source of heat.
Oct 03, 2010 | Gladiator Freezer GAFZ21XXRK
How do you get the back of the washing machine off
You should have a plastic cap on each side of the console.Unplug the machine. From the front of the machine, pop the caps loose. Under the caps are a phillip head screw. Remove both of them. Slide console forward and roll it back. Take a screwdriver and pop the two clips. Unplug the lid switch and roll the entire cabinet toward you. If you do not have the two plastic caps on each side of the console, look directly behind the right and left side of the console for the screws.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Cannon Laser Class 730i fax saying replace cartridge/when full
The machine is out of adjustment. Open the left panel and adjust the pot near the rear of the machine and turn it to about the 11 o'clock postion.
Feb 15, 2008 | Office Equipment & Supplies
Pool & Spa Logo
99 people viewed this question
Top Pool & Spa Experts
john h
David Spradling
David Spradling
Tom Chichester
Are you a Pool and Spa Expert? Answer questions, earn points and help others
