So it just says "laminator startup" and shows the printer as offline on fargo workbench, any tips?
It could be the laminator has gone bad. It could also be a timing issue with the startup sequence upon power-up. As you'll note, there are 2 power-supplies for the printer with laminator - one for the printer/flipper, and a second for the laminator. When powering up the system the laminator is supposed to be ready and respond to a query from the printer during its startup sequence. If the printer is ready before the laminator, then you can get such an error. To check for this, plug-in/power-up the laminator about 5 seconds prior to the printer to see if the behavior changes and it now works.
If results are the same, next double-check the connector between the printer and laminator to ensure there are no broken or bent pins or connector "fingers", and that the connection is secure. The gap separating the printer and laminator should be tight and even top-to-bottom as well, ensuring a good connection.
Also double-check your power-supplies. They should be identical and, if a recent model, will have a small silver sticker affixed that shows the printer serial number on it (check the manufacturer's plate your printer/laminator for serial-number, and make sure your power-adapters match it).
If none of the above resolve the issue, then contact your Fargo dealer for servicing or further support. If you don't have a dealer relationship and you're located in the USA, feel free to reach out to us!
Good Luck!
Safe-Card ID Services
Charlotte, NC USA
https://www.safecardid.com
SOURCE: fargo pro l lamination
I cant even get my cards to print the lamination on there. Can you please help me!.. Can you show me pics on how you installed the Lamination rolls. Also is there a special driver you installed or option you clicked beside the over laminate one. THANK YOU SO MUCH!
SOURCE: PCI Express error
make sure that the PCI Card is firmly fixed at its slot and lets notice if there will be a change..
If there is non then i guess you will have to swap the PCI card with a good one..
Please be very cautious when doing this or you can let an expert handle it for you..
I will love to hear the results.
Thankx
SOURCE: I need fargo pro L printer driver for windows 7
According to the Fargo Website:
http://fargosupport.com/archive_results.asp?archPrinter=5&archSubmit.x=42&archSubmit.y=5
The drivers only go as high as windows xp for now. Hopefully since Windows 7 is coming out soon that they will have a driver available for it shortly.
SOURCE: installation manual for fargo pro l printer
Check page 22 of the Pro User's Guide, you can download from FARGO support pages. Here are the links to the available manuals for your printer:
SOURCE: Model c6180 printer gives improper shutdown error
The printer is not getting enough power. When you get this error message it means the printer is being turned off by unplugging the power cord. In this case it maybe that the printer is not getting enough power due to being in a surge protector or perhaps the power module is no longer holding power correctly.
First step is to disconnect printer from any power strip, surge protector, or extension cords and plug in so directly to the wall. If printer still will not stop looping cycle you may need to contact hp for a new power module.
