Question about Whirlpool Washing Machines
What is the capacity of my Whirlpool Duet Washer model number: GHW9200LW?
Posted by Terry Plonka on
Ted Dornbos
The capacity of the Whirlpool Duet GHW9200LW (as well as the GHW9100LW) is 3.7 cubic ft
Posted on Sep 11, 2021
Roshan Tyagi
    New Friend:
Whirlpool GHW9200LW Front Load Washer 12 Cycle, 5 Temperature Ultra Plus Capacity ,Energy Star Qualified : Dove Grey on White. Machine Type‎: ‎Standard
Series‎: ‎Gold
Posted on May 08, 2019
5 Related Answers
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Error code F09/Whirlpool Duet front loading washer
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Try this first, and let me know if this corrects your problem. If not, you may need to check the pressure switch and wiring. I hope this helps you.
Posted on Apr 14, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: How to replace whirlpool duet GHW9200LW baffles
easy repair, they simply slide over hte slits in the tib and firmly pull forard to snap/lock into place. there should also be a screw included in the kit, remove the top of washer (3 screws across the back of the lid)after removing hte main top toull see a black accordian like hose leading to the top of the tub assy, from the dispensor box to the left. remove this hose from the tub( pulls out of the hole), then simply turn the tub form the inside till the baffle you installed is at the 12 o'clock positon your screw hole will be right there. RESECURE THE HOSE, reassemble the top and your done!
Posted on Nov 26, 2008
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: washer door wont latch ghw9200lw duet
Pulling the door open during the wash cycle meant that it was pulled open with the latch in the locked position. The door cannot be opened in this manner while it is operating. If the door now does not latch, it has probably been damaged and needs to be replaced. The following link explains how to replace the door latch:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
A replacement latch can be purchased on line at appliancepartpros.com. Just type in your model number and look under Section 5, for item number 7. The door latch is listed as part number AP3837611.
If you have questions, please let me know. I hope this helps you.
Posted on May 19, 2009
pctechexec
  • 4 Answers
SOURCE: My Whirlpool Duet Washer, model number WFW9400SW01 will not turn on. The button lock is off and does light up indicating power to the front panel/unit. Any ideas?
if you are mechanical and are not afraid of small wires you can try this. I had the exact same problem on my machine. i very slowly diasssembled the machine. not hard to do. removed the top. unscrews from the back and slides to the back to come off. remove the door. unsnap the plastic plate that goes around the door.it is held on by small snap clip that pop off if you use a small flat screw driver to pry it out. remove detergent tray. and screws that attach it to the inner box. now the hard part. remove the face plate. it unsnaps similar to large door plate.very carefully unclip the circuit boards. they are held in by plastic clips around the outside and white plastic clips in the middle. you must gently pry up and release these clips one at a time. a second person is helpful, so are small needle nose pliers. clean both circuit boards very gently with isopropyl alcohol and qtips. mositen the qtips and clean every inch of the boards. be very careful not to bend or crack anything. you must get all the yellowish flux and any other corrosion growing on the board off. there is one more board that must be cleaned. the power supply board. it is mounted on the top right side near where the face plate wire come through. this is not hard to remove it is held in by small clips. the tricky part is the wires. they are all designed so they cannot be plugged in incorrectly but i have seen what people are capable of. make a map. number them with a sharpie so you know where they go. remove this board and clean it the same way. this on will probably be the worst offender. i cleaned all the boards reassembled and it works like new. below the door is a panel that should also be removed. there is a removable drain filter that should be cleaned out. i found pens and toys in mine. the machine could not pump out the water fast enough and would shut down and trigger f70 and f 20 codes.
Posted on Jun 20, 2009
mifbaba
  • 32 Answers
SOURCE: Control lock light on
take a good look on control panel i don't remember which button you should push and hold for 3 for 5 sec. to lock or unlock control panel (it also called child lock) let me know it help or not. thanks....
Posted on Jun 24, 2009
3helpful
Whirlpool washer model GHW9200LW, THE CODE HF comes up ,tried the recommended fixes from the troubleshooting guide, but no luck
HF = High Fill
This can be caused by using non HE detergent in your front load. Put the washer in a cold rinse for a couple of cycles to clean the excess soap and try the cycle again using HE detergent. If the problem returns you may have a pressure switch or hose that will have to be replaced.
2answers
3helpful
WHAT IS THE CAPACITY SIZE OF MY WHIRLPOOL DUET WASHER MODEL NUMBER GHW9100LW2?
3.8 cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
2answers
Whirlpool washer door won't secure
Replace the wax motor and door lock mechanism.
3helpful
2helpful
Washer door wont latch ghw9200lw duet
Need instructions to replace the rubber boot (door bellow) on the whirlpool duet washer GHW9200LW
Here ya go...follow this link:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If you get stuck along the way and/or require further assistance, please let me know. I hope this helps you.
2helpful
The washer mode light keeps blinking
the machine is locked out on the control, go to the signal button on the far right side and hold the button in for four seconds and it will unlock the control and yu can select the cycle that you want
Washing Machines Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
