Question about Toys
E dry thing looks OK but string for mouth broken
Posted by Alan dalziel on
The bruches are not turning I have checked the reset switch nothing on the bruch
Ok. First check your belt. Is it broken? Then if that's not broken, check the ends of your beater bar for a build up of hair, string, etc. This build up will stop your beater brush from working. If you can clear that stuff away well enough you might get lucky and have it work for a while. Otherwise buy another brush/bar.
Dec 30, 2012 | Dyson Vacuum. DC24 All Floors Bagless...
Dean sings his arms and body move but his mouth does not i saw that someone replace d the string is there a diagram to show the workings of the doll
slide tux collar down and find 4 staples in neck, with small flat screwdriver work stales from neck, they are quite long and it takes some time. then with thumb under mouth at chin, gently wiggle and pull owtwards until mouth slides from head, mouth must be removed before head will lift from neck. once head removed, you will see drive motor near top that drives mouth. there should be a smoll nylon string connected to small plastic wheel on end of this motor, most times the adheasive that hold this string in place has let loose and string is still in tact. before reconnecting press activation button and be sure motor is spinning, if so simply reconnect string to plastic end, and reassemble head I used 2 part epoxy (JB Quick) Note if motor is not turning when activated then this too needs repaired
DW Mylin.
Sep 28, 2012 | Gemmy Bing Crosby Big Head Doll
What are the dangers with string cat toys?
There are many danger regarding yarn and string toys. There is the danger of choking by swallowing a yarn toy. In addition, the threads of the toy can become imbedded in the tissues of your cat, in its stomach and in its mouth. Furthermore, there is a danger that your cat will get tangled in the string, panic, and eventually hurt himself.
Aug 23, 2012 | Alfred Cats
Mouth does not move
Motor operating mouth assembly is bad. The process to remove it is tedious and the motor is specific to the design. This was a common problem with all of the motors in this series. Especially the one operating the mouth. The input pulsing necessary for the mouth to move, was to abusive to the motor, and subsequently shortened its life.
Dec 18, 2011 | Gemmy Bing Crosby Big Head Doll
Gemmy Dean Martin Mouth doesn't move. I took the head off by removing the 4 staples and can see the internal parts. There are 3 phillips head screws at the base of the head and 2 holding the plastic post...
Remove the staples to loosen the mechanism from the neck.
Remove the two screws holding the post to the mechanism base with a small Phillips screwdriver. Push the mechanism mouth out as much as you can to reveal the mouth post base. Using a hairdryer, heat up the mouth post glue and pull gently to remove the mouth bottom. Pull the mechanism out. Take off the spring. Replace the string with similar string. I would also recommend buying a new motor on ebay for $3 from China. You can get him singing again.
Feb 16, 2010 | Gemmy Toys
Our Singing Bing Crosby Santa doesn't move his mouth any longer, but his head and microphone still move while he's singing. Can we get his mouth repaired somewhere????
I have had the same trouble. I had to take his head apart and there is a string that is attached to the motor that works his mouth. The string has come unattached and needs fixed. The head is put on with a type of staple around the neck.Take them out and you will see what I mean.
Dec 14, 2009 | Gemmy Bing Crosby Big Head Doll
Gemmy Santa Bear mouth does not move
I would like to first tell you what the problem is with either your Bing or Bear head. Inside the head is a motor that works the mouth. On this rotating motor is a pulley type system, which has a twine or you could call a heavy string piece. It is attached to the motor, and when the is activated it rotates the thread round the spindle on the motor and the mouth operates.. It is quite a difficult to take this head apart. I worked on my Bing for some time to find out this problem.. The string comes away with use and of course time, that is is why the mouth no longer moves. If you wish to try and repair, you first have to remove the head from the base. If you look there are 4 heavy duty staples just round the collar neck area. They will come out with a small head screwdriver or something pointed. Just work it slowly under till staple raises up, then just pull it out. Once they are all removed the head should be loose. This is only to give you access to seeing the internals firstly. Now comes the hardest part. The soft moving part of the mouth needs to be removed. You need to work it of slowly as there is a glue base on it, so care is needed here and can take time. If you managed this all is left is the metal pin it was on. Now inside is the plastic unit that moves the mouth this is glued in which is the main problem. And this is the issue, it is pushed on and the only way is to remove is to have a precision head screwdriver and work it off... Best done by someone who is quite good with their hands and very patienced. Because it may break. Took me severals hours to remove. When you get it off the internal workings will come out of the head. There is no other way of doing this. Having the head loose allows you to look at the piece and the workings. A small torchlight held by someone is best as you work out the mouth fitting.....As i said it is no easy job and took me long periods of time to get to this point. I wish you all the luck in achieving this.......
Dec 15, 2008 | Gemmy Rocky Balboa Big Head Animated...
Horses mouth
I had the same problem with mine. There is **** in the upper part of the horses mouth if you gently pull it open a bit and look inside to the jaw area you can see where to reconnect the jaw and pop it back in place. There is also a wire connection near the mouth, so check and make sure this is also connected.
Dec 02, 2008 | Hasbro Fur Real Friends Smores Pony
Toys Logo
128 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
