Question about Photography
What memory card will SPDPF70E support?
I have a SPDPF70E digital picture frame. Powers on, but not wanting to recognize any memory card I put in it. I put in an 8G and 4G card. I'm wondering if maybe I should try a 2GB, because the frame is from 2007. Maybe the size is just too large for it to recognize?
Posted by Donna Schillinger on
5 Related Answers
Anonymous
  • 35 Answers
SOURCE: sd memory card not read by computer
Reformat the card from the camera. You didn't specify camera model but every digital camera has a menu to format media.
If you don't succeed try to connect your camera to the computer and read the photos.
If that doesn't succeed either take your camera to service.
Posted on Jan 16, 2008
Anonymous
  • 248 Answers
SOURCE: Philips digital photo frame 7FFI series
Here`s a tip i found for you...
1. Connect the frame to your PC using the supplied USB connector. Navigate to the \DCIM\100Frame directory and delete all the Phillips advertising pictures there.
2. Create a directory on your PC and put copies of all the pictures you want to display there.
3. Download the free picture resizer utility from Microsoft at:
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
(Look for Image Resizer in the right column). After installing it, "Select All" pictures in the directory you created, then right click and select "Resize Pictures" from the context menu. Choose the 640x400 radio button. Sort by size and copy all the small ones into the "\DCIM\100Frame" directory on the frame drive (Called Removable Disk on my PC).
Posted on Jun 20, 2008
Anonymous
  • 88 Answers
SOURCE: Unable to download pictures from computer to digital frame
The primary software is going to extract all the images, put only the images you want on the card, then insert into your picture photo frame.
Posted on Jan 08, 2009
Anonymous
  • 63 Answers
SOURCE: How do you unlock your memory cards for your digital camera?
take a look at the card it should have a switch on the side just slide it and it should be unlocked
Posted on Aug 01, 2009
Anonymous
SOURCE: I have a Brookstone digital picture frame that stopped working
I have encountered this same error on the frame I bought 2 years ago. I saved the pictures to a backup and then reformatted the frame - this didn't work - does anyone have any other solutions???
Posted on Jun 05, 2010
Kodak EX 1011 does not recongnize memory card
On the contrary. The EX1011 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and the frame will not recognize it as a memory card. You need to use SD cards, 2GB and smaller.
Jan 31, 2012 | Kodak EasyShare EX1011 Digital Picture...
How do you download pictures from phone to digital frame
Most digital frames require a memory card to display photos. The first step is to download your photos from your phone to your computer. Then you need to put the memory card you get for your photo frame into the computer if it has a built in card reader or into an external usb card reader. Next open the file that has the photos you want, and open my computer and select the memory card folder. Select the images you want and press control and c to copy them, click on the memory card folder and press control and v to paste them. Then remove the card and put it in the photo frame.
Jul 30, 2011 | Parrot 7-Inch Digital Photo Frame (Red)...
My children gave me a digital photo frame for Christmas. I have a Nikon digital camera. I have downloaded and deleted from my camera several pictures I would like to put into my photo frame. Am I able to...
If the "camera chip" you refer to is a removable SD Memory Card you need to put that into a SD Card Slot on your computer or use an USB Card Reader device. The computer will recognize the SD Card as a Disk Drive and you can use Windows Explorer to transfer the picture files to it.
Dec 29, 2009 | Coby DP-767 7-Inch Widescreen Digital...
How do I put pictures onto a memory card for a digital photo frame?
Once the computer recognizes the drive it will assign it a drive letter. Copy or send to the drive the pictures you want to display.
Nov 22, 2009 | SanDisk 2GB microSD Memory Card
I need instructions on how to load pics to my Optimus 07A08 digital frame.
On the back of the frame remove the memory card, then You need to use a pc with a Memory card reader, you can get usb card readers that simply plug in your usb, then copy all the pictures you want on the card from pc.
Oct 29, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Kodak EasyShare SV811 won't read SD / HD card
Compatible Card-Slots : SD/MMC; xD; CF;Memory Stick; Microdrive; USB
You might have too much data on the SD card. Try with less pics onto the card.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jun 25, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Jan 08, 2009 | SmartParts SPX8 Digital Picture Frame
Copying pictures from PC to the memory card.
When you connect your camera to the pc, via usb cable I presume, don't use the software that came with the camera, instead open the MY COMPUTER icon on the desktop, or in the windows START BUTTON. Your camera should in fact be recognized and appear as a new disk drive with its own drive letter or name.
If that happens, open the new drive window, and you should be able to see the folders that your camera uses to store pictures taken with it. It may depend on the picture frame requirements, but seems to me that you can now just drag and drop, cut, copy and paste any pictures you want right to the memory card drive, and I would not put them in any folder created by the camera, just on the memory card itself.
The other alternative is to purchase a memory card reader/writer for your type of card. They usually accept every card out there, and now you would be able to use that device to copy to and from the memory card without the need for a pc.
Hope that helps.
Dec 29, 2008 | Casio Exilim EX-S500 Digital Camera
I lost instructions to my Optimus 7" Digital Photo Fram
You can change out your pictures by having an XD or SD Memory cards if you have a card reader for your computer plug in the memory card put the photos on to it that u want on ur pic frame and plug it in to the xd/sd card slot on the left hand side of the photo frame and there u go. If you want ur pics off the internal memory u can transfer them from the frame to the card via the options button or menu button that is.
Nov 30, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
Westinghouse 7" lcd picture frame internal memory not recognized
You can copy files from internal memory to sd card only. Its one way data transfer.
Sep 05, 2008 | Westinghouse 7" LCD Digital Photo Frame
Photography Logo
157 people viewed this question
Top Photography Experts
Marvin
Marvin
Tony Parsons
Tony Parsons
Are you a Photography Expert? Answer questions, earn points and help others
