Can't see anything correctly because background is black and can't change it and don't know how it happened. like right now i am writing on a white screen but on my nextbook it is black
Hello. Go to settings, then display, and look at your wallpaper settings. That may help..
Https://www.techwalla.com/articles/how-to-invert-colors-on-your-computer-screen-to-white-on-black
It is unclear if you are experiencing a hardware problem or have inadvertently changed a screen setting. If a hardware problem, it would be a good idea to repost and to identify the brand, model, and operating system if such applies.
SOURCE: changing black background color
download the themes from net and then install it......................
SOURCE: Black Lines and dots on my screen
ur graphics card has burned out, same as mine. it happens with aerly models of wiis occasionally. send it to nintendo and theyll replace it
SOURCE: White screen with some colored vertical lines
christoph430. Your TV is hosed. Olevia will not fix it even if it is still under factory warranty. They are having lots of issues with their products and it will be too costly for them to pay for the repairs they should be covering. They are hoping you have an extended warranty through whomever you bought the TV from and will let that company deal with what should be THEIR problem. The repair company has to try to fix the TV at their cost. Nothing but a scam. We will never buy an Olevia TV again. Respond to [email protected] if you would like to understand details about our frustration with them. Unbelievable. Sorry for the bad news.
SOURCE: My monitor suddenly altered the colors on the
your monitor is either going bad or your display setting are messed up.use the buttons on the front and mess with color option if that don't work then you need a new monitor
SOURCE: Nokia 5800 display screen has gone white
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
