Check shutoff switch, wires for grounding, magnet strength on flywheel. If OK replace ignition module .
Posted on May 08, 2019
SOURCE: how do i replace the pull cord on my stihl cut off saw
it is gonna take some time,take all screws off housing,pull casing off,be careful with the rewind spring and be sure you have spring wound-up for re-install.
Posted on Apr 24, 2009
SOURCE: hi there; my stihl ts 420 does not start easily
replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
Posted on Aug 03, 2010
SOURCE: where is location of serial number on a 420 stihl
The Serial is engraved into the aluminum right next to the muffler. Look from the top down and you will see it.
Good luck
Posted on Feb 22, 2011
SOURCE: not getting spark when starting
[email protected] HI GRYDERT your problem could be your on, off switch. This might sound funny, but switch the on off switch real fast several times, then see if you havee fire. If not check your spark plug. If you have a n
ew one try it. If that don't work check the connection at the plug to be sure it is makiong contact with the plug. If all this does't work you will have to go inside to the coil. They don't usually go ba d but it could. But first check to be sure it isn't grounded at the small wire from the switch. Good Luck.
Posted on Jul 01, 2011
if this machine ran ok before this problem,and no one has adjusted the carb,then i would check the crank seals.i have just had this problem.and it was the seal on the puller side,though i replaced both whilst i was at it.hope this helps my freind.
Posted on Jan 30, 2012
Apr 13, 2014 | Stihl Ts 410 420 Cut Off Saw...
Mar 15, 2014 | Stihl Ts 410 420 Cut Off Saw...
Dec 31, 2013 | Stihl Ts 410 420 Cut Off Saw...
Mar 25, 2013 | Stihl Ts 410 420 Cut Off Saw...
Dec 12, 2012 | Stihl Ts 410 420 Cut Off Saw...
Aug 15, 2012 | Stihl Ts 410 420 Cut Off Saw...
Aug 29, 2011 | Stihl Ts 410 420 Cut Off Saw...
Dec 27, 2010 | Stihl Ts 410 420 Cut Off Saw...
Nov 07, 2010 | Stihl Ts 410 420 Cut Off Saw...
Jun 16, 2010 | Stihl Ts 410 420 Cut Off Saw...
May 08, 2018 | Stihl Saws
137 people viewed this question
