Question about Kicker Car Audio & Video
SOURCE: Kicker L7 Repair
With the price of speakers dropping all the time it's really not worth repairing as it will cost too much to have it fixed by hand.
Posted on Dec 28, 2007
SOURCE: kicker amp
if you amp is in the PROTECTION MODE its means that there some defective part , like for example the main ICs or TRANSISTORS output might be defective , and thats why its on the PROTECTION MODE , needs to be taken to a expert technician for repair.
Posted on Apr 16, 2008
SOURCE: best amp for Kicker Sub
Hello dalex7,
The Kicker 08ZX400.1 would be a great amp for your subwoofer. It will work into a 4ohm load with no problems.
But you can buy an amp with more power, looks better, has a smaller footprint, and cost less than the 400.1. I'd look at the Alpine MRP-M500. Take a look at it here at Crutchfield. The M500 is also easy to install, runs cool, and is very efficient.
Hope this helps.
Posted on May 21, 2009
SOURCE: wiring diagram 354xi kicker amplifier
do you need the internal schematics, or how to hook it up? let me know.
Posted on Jul 05, 2009
Jul 19, 2016 | Kicker Car Audio & Video
Nov 09, 2012 | Kicker Car Audio & Video
Aug 23, 2012 | Kicker Car Audio & Video
Jun 30, 2012 | Kicker IK150 Digital Docking System w...
Mar 17, 2012 | Kicker 06ZX750.1 Car Audio Amplifier
May 04, 2010 | Kicker CVR12 Car Subwoofer
Oct 08, 2009 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
Jul 12, 2009 | Kicker SX650.1 650W Mono-Block Amplifier...
Jul 11, 2009 | Kicker 02S10L74 Car Subwoofer
Hi yeahonda,
Your Kicker L7 Ohms may be too low for the MA Audio Mono block amp. The MA Audio Amp is probably 2 Ohm Stable. The kicker will either be 2 ohm or 4 ohm Dual voice coil. To eliminate the low ohms as a possible threat to causing the map to go into Protect, Wire the kicker Voice Coils in Series. This adds the ohms, so that you either have 4 or 8 ohms.
I am using the following codes to show wiring. VC1+ stands for the Kicker Subs Voice Coil #1 Postive post. AO+ is the MA audio Amp output positive.
AO+ to VC1+
VC1- to VC2+
VC2- to AO-
This shopuld give you 4 or 8 ohm depending on the 15" L7 setup. Crutchfield does not carry the Kicker L7 in 15" They do have the L5 in 15".
If you know how to read a Volt Ohm Meter, set it to OHMs 20 and measure across VC1+ to VC1- and you should see between 1.5 and 5 ohms.. Do the Same with VC2+ to VC2-. you should see the same voltage. Also read from the Voice coil metal housing to VC1+ , VC1-, VC2+, and VC2-. and you should not read any ohmage to the case. The meter should say OL, or -1.
Good luck.
Oct 15, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Jun 29, 2019 | Kicker Car Audio & Video
Aug 17, 2018 | Kicker Car Audio & Video
231 people viewed this question
