Go to set up tv air and channel search
SOURCE: How to update digital channels correctly
the information I needed was in the FAQ's area. Thanks
Posted on Jun 06, 2009
SOURCE: olevia not searching channels
try the following..
Q.
Why are the menu settings that I changed not being saved?
A.
The TV is in Showroom mode. The following steps will help you switch to Home mode.
***Showroom mode is designed for retailers to display the TV and to protect from shoppers changing the settings that are predetermined for shelf display environment.***.
Q.
Why does my TV display "No Signal" or "Channel not in List"?
A.
Channel search needs to run the very first time of use or after the default settings are loaded from the OSD menu. The following steps will guide you through the process.
Posted on Jul 29, 2009
SOURCE: Channel search on samsung 933HD tv
Go to d.menu on your remote, scroll down to the second icon (the satellite dish) and press auto store. It'll scan for any freeview channels available
Posted on Oct 01, 2009
SOURCE: I bought an Alba CDVB4 and the remote isn't right
Hi
Not sure if you found the problem for this, but I had the same problem and couldn't find any reference to this except your question so thought I would put up an answer in case it can help you or anyone else.
Aparently, Alba have got hold of the codes that Toshiba use for their remote controls, so if you have a Toshiba telly an Alba product like this won't work. The only solution being to return it and get a different make.
I returned mine twice for a straight exchange thinking it was just a manufacture fault before I found this out. I then exchanged it for a Bush set top box - only a fiver more - and it now works PERFECT!
I hope this helps some.
Zoe
Posted on Feb 21, 2010
