Question about Kyocera Office Equipment & Supplies
I have kyocera 2035mfd printer why i scan to send to mail it shows error 1105
Posted by karan on
Eric Janssen
    New Friend:
    Problem Solver:
  • 5 Answers
Check the checkbox in the setting for SMTP. You have to switch the SMTP on !!
Posted on Jun 13, 2019
5 Related Answers
Anonymous
  • 54 Answers
SOURCE: kyocera printer no.1118 cannot scan
This is a scan to email error code
The scan isn't registering the dns servers properly, so the smtp server name isn't getting resolved. Replace the server name with the server ip and this should resolve you error. Let me know how this works for you.
Please remember to rate me.
Posted on Feb 02, 2009
Anonymous
SOURCE: kyocera cs 1820 error 2102 using ftp
I reset the IP adderss to another printer on the network and it worked so it looks like not all printers are compatable
Posted on Jun 17, 2009
Anonymous
SOURCE: Scan error C3200
remove the flat wire in the scanner, then remove the railings from the scanner, clean the railings with a soft cloth, if you encounter the c3200 error it only means that the railings of the scanner is dirty, the scanner cannot move. i hope this will fix your problem..... if you have anymore questions regarding kyocera copiers dont hesitate to txt me or call me to this number +639081953003 or +639079941995
Posted on Aug 17, 2009
shawn38
Shawn
  • 200 Answers
SOURCE: Cannot send pdf via e mail using manuf gui - How do I workaround auto space after dot after I type in e-mail address which invalidates the e-mail destination.
It sounds like you need a firmware update. You will need an authorized thec do this.
Posted on Mar 06, 2010
dj_relly999
dj_relly999
  • 4070 Answers
SOURCE: kyocera 3035 scanning to e-mail
Hi! EO24 will mean SMTP authentication error. Consult with your network administrator to verify that the login account name and password required for SMTP authentication are correct. Hope this helps and thank you for using FixYa!
Posted on Sep 13, 2010
Error 1105
error 1105 is E-mail The SMTP protocol setting is turned off. Use Command center and turn on
Oct 17, 2011 | Kyocera Copystar CS-1820 Black and White...
When i scan to email, i get an error; "send error 2202" and the document is not sent to email. The Kyocera fs-1028mfp printer is connected to the LAN using a network cable.
Apparently there is a communication error between the printer mail server. Can you ping both reliably ? Is it an internal mail server ? If yes, can you ping the printer from it ? Did you try changing the network cable ? How about IP addresses ? Could there be a conflict ?
Cheers,
Franck Horlaville TAM Software
Sep 12, 2011 | Kyocera FS-1118 Printer
Kyocera 5050 error code 2202
This is an error is indicating a connection error when using the send feature.
Below I have provided some information or for more information download the users guide from the manufatcures website using this link. http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=16088&rid=16313
2101, 2102, 2103, 2201, 2202, 2203, 3101:
The network cable is disconnected or the hub that it is connected to is not operating properly. Check the cable and the hub. Otherwise, the server name or the host name of the SMTP server is
not set correctly. Use COMMAND CENTER and register the SMTP server name and the host name
correctly.
2204: The E-mail size exceeds the acceptable send data capacity. Decrease the size or resolution of the scanned data to be transmitted and resend the E-mail. 5101, 5102, 5103, 5104, 7102, 720f:
Turn the main power switch off and back on. If this error occurs several times, make a note of the displayed error code and contact your service representative.(Refer to the corrective action for the error message " An error has occurred.")
9181: The scanned original exceeds the acceptable number of pages of 999. Send the ecess pages separately.
Hope this is helpful,
Shawn
Mar 11, 2011 | Kyocera Mita KM-5035 Printer
Km-3035 (kyocera) send email from scanner key, eveything seems to go fine, but no one gets emails, going into history of sending I find error E022. manual is no good, it give no codes. searched google, no...
The E022 error indicates -
The mail contained an e-mail address that the SMTP server can not find.
Check to make sure that the destination e-mail address was entered correctly.
The link below will take you to the manufactures web page where you can download the Scan System Operation Guide (Function Edition which list the error codes.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=11796&rid=14242
If you continue to have a problem you can go to www.gfbm.net for more assistance, also they have some Kyocera setup and troubleshooting information.
I hope this is helpful,
Shawn
Feb 24, 2011 | Kyocera Mita KM-3035 All-In-One Laser...
Code error 1102
The 1102 error code means that the login user name is incorrect or the domain name has not been entered. You may need to reneter the login user name, domain name and password.
Jun 07, 2010 | Kyocera FS-1118MFP Laser Printer
0x3101 error on kyocera when trying to send scan to email
you can not scan usb, it has to scan via network cable via the scan card . you can use quicksetup utility to log in to the scan card and change the destination ip address of your tower. as long as your tower has a static IP sddress , should be applied via web interface of the scan card..
Nov 02, 2008 | Kyocera Office Equipment & Supplies
Kyocera FS1118 mfp
FS1118 scanning issue - this may sound like a long process but its easy...
Just create a folder called scans in your c:/ drive right click and share the folder
Go to the kyocera command centre (type the ip address of the machine into your browser, taking note your machine must be networked)
Once in kyocera command centre
Click on basic
on the left menu select address book, contacts
create a new contact and under SMB
only insert your computers IP address in the host field
and insert the file name scans in the path field.
Click submit...
Once complete go to your machine
insert a page to scan, select the send button
press the address key
select the contact you created
select ip address press enter
now press 2 on the keypad
press enter
press 2 again
enter again
and then press the green start button once complete..
The scanned document will appear in the scans folder
Aug 01, 2008 | Office Equipment & Supplies
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
