Question about Video Cameras
Camcorder won't come on is there a reset button
Posted by Rodney Runge on
barrybam
    Sergeant:
  • 208 Answers
Very often these older camcorders have internal batteries that give out so you need to plug in the power card and that should at least let you use it using the charging system. It may take awhile before some juice is picked up by the old internal battery and then try it. You may be able to buy a new rechargeable battery for it on eBay.
Posted on May 07, 2019
Reset button trv57 camcorder
If you mean the counter reset button, it's the third button on the top row sheltered behind the flip-out display. See the illustration on page 82 of the manual.
Mar 19, 2012 | Sony Handycam CCD-TRV57 Camcorder
My Sony DCR-TRV240 camcorder won't eject the tape. The power and all camera features work, but it won't eject a tape.
I'm sorry that the Camcorder is not ejecting tape. Please follow the troubleshooting steps provided below and check the operation:
1. Please make sure that the battery is fully charged. 2. Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder. 2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds. 3. After 2-3 seconds has elapsed, release the RESET button.
3. Perform a manual power reset by following the steps:
1. Turn off the camcorder. 2. Disconnect AC power adapter. 3. Remove the battery pack. 4. Move the POWER switch to the CAMERA position for 15 seconds. 5. Move the POWER switch to the OFF position. 6. Reconnect the AC power adapter or reinsert the battery pack. 7. Turn on the camcorder.
If the issue persists after following all the steps service will be required. You can find repair information and initiate service at:
http://fixya.com/repair
Thank you for using Fixya. Please let me know if you require any clarifications.
Sep 01, 2011 | Cameras
My clients are complaining about the darkness of my movies taken with this DCR-H30 camcorder.how can I adjust the settings of the camcorder for perfect results
the camcorder is suppose to give you good result even on its default settings. try to reset it first by pressing and holding the reset button.(reset button is located in the panel where the lcd screen comes from. its a tiny hole and you can use any pointed object to press and hold it for 3 seconds. try recording again. if you're having a hard time looking for the reset button, try removing ll power source from the camcorder(battery and unplug it from walloutlet) then press and hold power button for 1 min.
Sep 07, 2010 | Sony Handycam DCR-HC30 Mini DV Digital...
My LCD touchscreen on my DCR-SR45 fades to white
To resolve the issue,
Please open the LCD screen to locate the RESET button.
To reset the Camcorder, just press the RESET button using a sharp-pointed object.
Please make sure that the Camcorder is turned on while pressing the RESET button.
If the issue still persists, Power Reset the camcorder.
To reset the Camcorder, please remove the batterypack from the Camcorder and then set the Power Switch to ON for 15 seconds.
Then, reinsert the batterypack after 1 minute and check if that helps.
Mar 20, 2010 | Video Cameras
I just bought an i- link cable (4 pin to 4 pin) and I cant capture videos using sony DCR- HC35e in windows vista. How do I fix this?
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer. Open the Windows Movie Maker Application, select the option "Capture" from the File menu and follow the on-screen instruction to transfer the Video to the Computer.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Dec 10, 2009 | Sony Video Cameras
I have a Sony DCR-TRV27E camcorder. For some reason I can't get it to transfer from camcorder to computer. I have been doing this for years, but it has suddenly given up the ghost!! I have tried with...
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
Sep 15, 2009 | Sony Handycam DCR-TRV27E Mini DV Digital...
Can't turn off nightshot on my handycam help!!!
Option 1:
Using the NightShot:
1. First Set the POWER Switch to Camera, Slide NIGHTSHOT to ON.
2. The NIGHTSHOT indicators flash on the screen.
3. To cancel the NightShot mode, Slide NIGHTSHOT to OFF.
Option 2:
1. Let us try to reset the Camcorder and check if it helps to resolve the issue.
2. Locate the RESET button behind the LCD screen of the Camcorder.
3. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object.
Good Luck!!!!!!!!!!!!!!!!!!
Sep 13, 2009 | Sony Handycam DCR-TRV16E Mini DV Digital...
I'm trying to clean the heads on my TRV 950, I purchased a cleaning cassette and this error code appreas on the lcd c:31:22
Follow these steps to resolve the issue:
Step 1: Remove the cassette and insert it again , then operate your Camcorder.
Step 2: Try using different cassette.
Step 3: Try resetting the Camcorder.
[Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.]
Please locate the RESET button behind the LCD screen of the Camcorder. Press the RESET button using a sharp-pointed object. The Camcorder should be switched ON when you reset the unit.
Step 4: Try to power reset the Camcorder and check if it helps to resolve the issue. Power Reset the Camcorder by removing the batteries from the Camcorder and inserting it after 1 minute.
Step 5: Service is required.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C79466
Aug 12, 2009 | Sony Handycam DCR-TRV950 Mini DV Digital...
Panasonic camcorder NVDS 27
After a deep study of the manual there are two reset buttons. One on the remote (pg 8 #4). The camera reset is next to the tape eject button. (pg6 #25). Hope this helps.
Dec 13, 2007 | Panasonic NV-DS27B Mini DV Digital...
My camcorder doesn't work
For Models: CC4252, CC4352, CC4362, CC4392, CC4393 You need to reset your camcorder. Follow these steps: * Remove the power source. * After one minute, gently press the RESET button with a nonmetallic pointed item until you feel a "click." This resets the camcorder to the factory settings and erases the date, time, and custom settings. * Wait for at least one minute after resetting the camcorder to attach a power supply.
Sep 06, 2005 | RCA CC-432 Camcorder
Video Cameras Logo
122 people viewed this question
Top Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Al Rush
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
