SOURCE: Sony 46" XBR2 Cannot turn off closed caption
With TV on, turn off DVR and hit menu on DVR remote - you can disable CC from there. Worked for us - got the idea from another fixya post.
SOURCE: Closed Captioning comes on every time i turn on the tv!
Apparently the 2002 Sharp model TV that I purchased has the closed captioning by default if the mute button is engaged. So there is no solution for my particular model, it has been built in this way. The only solution is not to use the mute button and lower the volume instead.
SOURCE: I can not turn off
I have direct tv, and had the same problem. After an hour on the phone with the worthless tech, I gave up. Finally I figured it out. First of all do you have closed caption problems or is it "subtitles". mine turned out to be direct tv subtitles, not closed caption. I hit the yellow button on the direct tv remote, and presto. Subtitles was set to the on position. changed it to off, and what do you know. fixed.
