Question about American Standard Home
We have a wall mounted American Standard toilet from the 1970's. The tank has a crack in it. Is it possible to just change out the tank?
Does anyone know if the fittings for the 1970's era toilet would fit a wall mounted tank I can find online today? This is original pluming to the house built in 1970. A plumber wanted to come in and re plumb the entire thing changing our plumbing from wall to floor. This is very pricey and a lot of work. We only have one bathroom in our house.
Posted by D Griffith on
jdthefixer
  • 746 Answers
First, carefully remove your tank lid, and place it where it won't break or fall. Look for a four-digit number located on the back of the tank, near the water level mark. This is your tank model number. If the number starts with a two, it is a one-piece toilet.
Then....visit this link:
https://www.americanstandard-us.com/parts-support/faqs/toilets
Good Luck!
Posted on May 06, 2019
5 Related Answers
keemo68
Ronald Mueller
  • 1263 Answers
SOURCE: Water Tank Will Not Stop Running Water
the reason your water keeps running is because the float has not closed of the valve in the stem on the left side. a quick fix is i take the rod that has the float on it and bend it down a little. i also make sure that the plug that fits over the drain seats properly alot of times through age the plug tends to harden up and not seat properly. if you cant get it to seat replace it. if your model has an adjustment screw on the valve body try adjusting that as well.......good luck please rate this
Posted on Sep 03, 2008
Donni Steen
  • 687 Answers
SOURCE: PLUMBSHOP HUSHFLO #516 Toilet anti-siphon/valve
Usually, there is a diaphram located at the needle valve that can be removed and cleaned and or replaced. If you know you have grit in the water, then you are right, that will cause problems with the fill valve not fully closing.
Posted on Mar 20, 2009
Fred
  • 62 Answers
SOURCE: Looking to buy/install Toto Aquia II in my circa 1964 co-op apt.
When you say 10.5 inches from wall, do you mean that from the center of the drain in the floor to the back wall is 10.5 inches? If so, you need a toilet for a "10 inch rough-in" dimension. The Aquia doesn't come in that dimension. Sorry!
Caroma Sydney Smart model 270 comes in a 10 inch rough-in and is a dual flush model. Note that all dual flush toilets are fairly expensive as compared to normal toilets. HOWEVER, genrally speaking, ALL 10 inch rough-in toilets are fairly expensive just because the low volume that are sold.
Posted on Jul 11, 2009
Anonymous
  • 7 Answers
SOURCE: I have an aqualux whirlpool tub w/ cracked jet housing
yes i can do it call me 301 659 9968 rick
Posted on Oct 31, 2009
Anonymous
  • 534 Answers
SOURCE: american standard thru-wall heater air conditioner
sounds as if the heater coil itself is burnt out. These coils may be repaired if you can get an universial coil repair kit and rewire the heater coil yourself. Since the age of the unit is in question I don't know if it is possible to get a kit for repairs but you never know. I would check an a/c supply house for this kit. Good Luck on your repairs
Dave
Posted on Nov 03, 2009
Testimonial: "The Solution was one worth considering and helpful in further troubleshooting. Problem turned out to be the elecronic circuit board."
Leaking toilet tank
Is the tank cracked or is it leaking from the bolts that go through the bottom? If the bolts are leaking shut the water off, Should have a shut off valve behind the toilet, If not possible around your house. Mine is out by the road where the water meter guy can check it. But shut the water off and put 2 new bolts and gaskets through the toilet. Very cheap fix. under $4.00 USD
Mar 10, 2015 | American Standard Home
I have a problem with the water in the tank leaks past something, maybe the flush valve assembly and the tank has to refill about every 25 min. I got a new flush valve assembly and changed it and put...
Hi keithn60...
I had the same problem one time with my toilet tank, the answer is to put some silicone on the seal washer between the take and bowl assembly and to use a level on the tank to tighten it just enough to be level and not leak.
Please take time to rate me
Jun 27, 2011 | American Standard 4021 White Cadet 3...
I am installing 2 new american standard champion 4 toilets and on both of them the tank will not sit on the base. the thick rubber gasket seems to be too thick to allow this. i don't want to crank down too...
The reason the tank doesn't sit down on the bowl is cause it's not supposed to just sit flush from the start. Your suppose to tighten the tank bolts down in order to get a water tight seal. There is also these little rubber " U " shaped things that sit on the porcelain lip on the back of the bowl thats what's there to protect it from cracking when you tighten the bolts down. Just place 1 on the right side and the the other on on the left side. and tighten down 'til the tank touches the bowl.
Nov 17, 2010 | American Standard AMERICAN STD 12 RGH...
American Standard toilet rear gasket is leaking
Check that the two bolts holding the tank are tight, if they are then remove tank and replace the gasket
Nov 06, 2009 | American Standard Glenwall Pressure...
I hear noises and feel vibration from the wall behind the toilet tank. When I lift up the toilet water tank cover or flush the toilet, the noise and wall vibration stops. However, the same noises and...
Your ball **** needs replacement (water control valve), Also your flapper or tilt valve disk is leaking water through it and it needs replacement also.
Sep 09, 2009 | American Standard Toilet Tank ...
My American Standard toilet flushes okay but when it is filling up the water will not stop running unless I lift the top and depress the lever.
Replace the fill valve. You can pick one up[ at Home dep or Lowes for about 20 buks. Close your angle stop at wall behind toilet. Drain all water from tank then remove supply loine from under tank. Then unscrew fill valve and remove gasket and all. Remember to put gasket in new one. :)
Sep 07, 2009 | American Standard Colony 2388.012.222...
Wall-mounted toilet has a crack and is leaking. Can a ceramic toilet be glued and with what?
If you don't care about seeing the repair use the product that Smithbrother recommended it works great. Other marine epoxies would also do it. They can be purchased in any hardware store, including the box stores like home depot and lowes.
Mar 14, 2009 | American Standard Home
Home Logo
130 people viewed this question
Top American Standard Home Experts
Mike
john h
Ekse
Are you an American Standard Home Expert? Answer questions, earn points and help others
