Question about Photography
My digital frame stopped after 6 pictures. - Photography
Posted by Gail Cahill on
Tony Parsons
  • Photography Master
  • 6,301 Answers
Stopped doing what ? If it stopped showing the pictures, check their size, rotation and format. If it powered off, check the batteries or mains lead.
Posted on May 06, 2019
Pictures not showing.
make sure the cards' slide button is in the unlock position..then check to see which size cards the frame can work with..mb sizes like 2/4/6/8/12 etc..
Jan 11, 2014 | Audiovox DPF700 Digital Picture Frame
How do you add pictures to the photo fram:
Use PhotoFiltre free photo editor program to edit your pictures.
You may download it from the below link.
http://www.4shared.com/file/gqHN4jSz/pf-setup-en.html
1. Photos should be in .jpeg format.
2. It is better to scale your photos with the above editor to 800x600 pix.
3. Prepare your pictures in a PC using PhotoFiltre. Scale all the pictures.
4. Transfer your pictures from PC to a USB Flash Disk (Memory Bar)
5. Plug USB Flash Disk to your Photo Frame.
6. Probably your photo frame will ask to transfer your pictures from flash disk to internal memory. Accept this and by pressing enter/OK/Set (Any button that changes from one product to another.)
I think it helps.
Jun 15, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
Remote control for Smart Parts 11" digital frame (SKU SP11008) doesn't work. Have changed battery, but cannot get any type of connection between remote and frame. Received as gift over a year ago, but did...
We have to check the remote control first. After that check the digital picture frame.
Follow the instructions below please;
We must be sure the remote control is working;For this control:
1. Take a digital photo of this remote control while pressing the remote control button.
2. If it is working then the picture must shows the led lamp of remote control as firing.
3. If the picture does not show that it is firing, then, you should control batteries of the remote control.
4.Check the battery and the battery polarity of the remote control.
5.If it is firing. You should control Digital Picture Frame.
6. If the battery of the digital picture frame does have enough energy or not. If battery is low then you shoud use it from the closer distance.
7. I do not think that the Digital Picture Frame is out of order.
Regards.
Apr 21, 2010 | Smart Parts Digital Picture Frame
Can i leave my digital frame playing all the time
There should be little problem with it being left on all the time, the frame should be able to run indefinitely with little defect. Make sure there is nothing like drapes or books etc around the frame so it can give off the heat that will naturally occur from being left on all the time.
Feb 22, 2010 | Kodak EasyShare EX1011 Digital Picture...
How to repair a digital picture frame
My photo frame comes on but the blue light on the side flashes when it stops it says Please wait on the frame and doesn't come of that :(
Anybody know how to fix it??
Thanks
Jul 25, 2009 | Westinghouse DPF-1021 Digital Picture...
Can't seem to stop the device to safely remove hardware
if you know it is done transfering the data you should be able to remove it safely even if that message pops up.
Jun 13, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Cant copy any pictures from computer
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Feb 03, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Can't transfer photos from computer to digital frame
1. Install EasyShare software (free download at www.kodak.com/go/sw)
8. Unplug the USB cable and on the frame check the pictures that were just copied.
Jan 17, 2009 | Kodak EasyShare M853 Digital Camera
I can't transfer pictures from my computer to my digital frame. When I connect my usb cable to my computer from my digital frame , the frame displays "Connected to computer. Use PC interface to copy files....
Dec 26, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Photography Logo
159 people viewed this question
Top Photography Experts
Marvin
Marvin
Tony Parsons
Tony Parsons
Are you a Photography Expert? Answer questions, earn points and help others
