Question about Coby Audio Players & Recorders
I plugged in my coby mp605-2g into my computer and the computer said there was a problem with it and did I want to fix it, I clicked yes and it hasn't powered up since
Posted by James Durham on
Does not charge or play,read on computor
In order for the Coby to charge while connected to the computer or other charger, the Coby must be OFF before being connected to the computer. Check the following questions....
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and photo folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging in the battery area - upper right hand corner.
It will appear to be charging all the while it is connected to the computer. After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge with the player OFF.
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Go to the DEVICE TAB
2. CLICK on EJECT Button in lower right hand corner.
3. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
4. The second pop-up screen will tell you "The device can now be safely removed from the system."
5. The Coby will now show "Please Wait..."
6. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Let it run on music until it turns itself off. Recharge as above.
Hope this helps.
Not sure if player is charging
QUESTION ONE:
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
QUESTION THREE:
QUESTION FOUR:
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
e. You will see a USB connector icon on the player screen and the player charging.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
Hope this helps.
My Coby mp3 player won't connect to my computer
QUESTION ONE:
QUESTION TWO:
QUESTION THREE:
QUESTION FOUR:
c. Make sure the player is TURNED OFF ! ! !
e. You will see a USB connector icon on the player screen and the player battery charging.
It will appear to be charging all the while it is connected to the computer. After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8-16 hour charge with the player turned OFF connected to the computer.
IT WILL NOT CHARGE WITH A COMPUTER UNLESS IT IS TURNED OFF WHEN YOU CONNECT IT.
(Found HERE if you have had to format the player)
Hope this helps
I have a coby mp-610 and I just took it out of the box and plugged it in to my computer. Nothing comes on, nothing. I've hit the reset button. I've turned it off and on. It doesn't even show it's charging....
COBY PLAYER MUST BE TURNED OFF WHEN BEING ATTACHED TO A COMPUTER...
QUESTION ONE:
QUESTION TWO:
QUESTION THREE:
e. Let your computer recognize it.
f. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer. After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8-16 hour charge with the PLAYER OFF the COMPUTER ON.
f. Use the Coby Manager to disconnect the player (Found HERE If you've lost your copy on the player)
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter horizontally as the battery is wearing down.
Hope this helps
2answers
How to i download songs from my music to player
open my music
and my computer
when in my comp... open colby file 4 ur player open music folder on player then drag ur music from :my music to you player
hope this helped
I have a frozen Coby MP610 8G how do i fix it?
Here are instructions for a solution to your frozen Coby 610 problem.
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the zipfile from the Coby Website will give you a PDF file with instructions, and a program file to run.
Your music will be erased when you run this firmware update. The instructions suggest that even if your mp3 player won't startup properly, if you plug it into your computer you should be able to access it as a removable disk, and copy all your music to a temporary folder on your computer.
Here are the steps:
  1. Plug your MP610 into your computer.
  2. Copy all your music to a temporary folder.
  3. Disconnect your MP610 from your computer.
  4. Disconnect as many USB devices as possible from your computer (to simplify identifying the MP610 at a later step, and avoid damaging other devices by trying to load the MP610 firmware into them by mistake.)
  5. Run the Firmware Update program 'MP610 T LCD Firmware Update for file sys err.exe'
  6. You will see a screen with up to 24 numbered, empty boxes.
  7. Connect the MP610 to your computer. It will show up in one of the boxes.
  8. Once the MP3 player shows up, click on the Firmware Feature icon to start the firmware upgrade.
  9. After the firmware update is complete, you will receive a checkmark in the firmware box.
  10. Disconnect the MP610.
  11. Close the firmware update software.
  12. Turn on the 610 to confirm it starts up and the display reads 'COBY'.
  13. Plug it back into your computer and copy your music back on to it.
You can refer to this Coby 610 solution here.
I hope that helps.
I plug my coby mp3 n the computer can't read it
Here are instructions for a solution to your frozen Coby 610 problem. This works even though the MP3 player is having problems talking to your computer. They should communicate fine after this update.
Here are the steps:
I hope that helps.
2helpful
2answers
My coby mp3 mp-610 keeps saying file sys err hod do i fix it
hope u got this fixed but if not i know where you can go to cobyusa.com and put the model number in product search the click firmware and download to ur desktop. open it up and u will have 24 grey boxes then plug in the mp3 and clik the firmware button right below box 24 one there is a green check in box 1 then its fixed and u can disconnect it and re add ur files
4helpful
Coby mp305 usb stick w/ fm radio display says file system error & wont allow me to access menu to use fm radio or anything. cobys website has proven to be worthless. any suggestions would be appreciated....
I just fixed my co workers device. Plug in the device into the PC after it plugged into the pc, the pc will detect the device after the device is detected. In My Computer, double click on the coby device, it will bring you to the the storage device, its also named coby something. right click on it and format. You'll lose all your data but the file system error message will be fixed. Reload music and you're back and running.
2answers
How can i reformatt my coby mp3 players
You can plug it in the USB then on your computer go to start then My computer it should show up under removable storage. Right cilck it then click format.
Top Coby Audio Players & Recorders Experts
Jean Sintulaire
Ekse
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
