Question about LG Washing Machines
Lg wt5170hv spins but does not always drain. drains best on low spin cycle.
Posted by Ed Dudash on
john h
    Top Expert:
  • LG Master
  • 23,424 Answers
Check drain for clogging
Posted on May 06, 2019
Testimonial: "Drain hose is clear and drain seems fine when it is pumping water out."
  • john h May 06, 2019
    check at the pump possible debris
  • Ed Dudash May 06, 2019
    Drain hose is clear and drain seems fine when it is pumping water out. Sorry about adding commen to testimonial section.
5 Related Answers
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: LG Top loader not draining water to rinse and spin
YOU NEED TO CHECK THE WATER PUMP,SO LAY THE MACHINE ALL THE WAY DOWN ON ITS FRONT,NOW YOU HAVE ACCESS TO THE PUMP.Remove any debris that may be lodged inside of it.
Posted on Jun 09, 2008
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
Posted on Jul 22, 2008
Anonymous
  • 33 Answers
SOURCE: LG TROMM noise during spin cycle
Dear Customer,
for ur water not drainin out, please do the the followin checks
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
  • n for ur rattling during spin cycle please do the followin checks..
    Please read our safety information before attempting any testing or repairs
    Before working on the washer, unplug the appliance or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
    A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive noise. There can be several causes and the problem is worse with some machines more than others.
    The most common cause is an unbalanced wash load. Open the lid and when it comes to a stop, redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit.
    A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See our article on how to level your washing machine.
    The outer tub is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons may begin to wear out and not support as much weigh as needed.
    Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be called for.
    Another common cause for excessive movement is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.
    There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
    • General tips mentioned above
    • Balance the load
    • Level the machine
    • Inspect the water pump for a blockage
    • Inspect the coupling
    • Inspect the transmission
    • Adjust the drive belt tension
    • Check the motor bearings
    • Check the drum brakes
    Please rate this solution.Thank you..
    Posted on Dec 16, 2008
    Anonymous
    • 187 Answers
    SOURCE: LG WD 8013F drains then won't spin
    • Hi,
    • Try these:
    1. Test the lid switch
    2. Test the timer control
    3. Test the centrifugal switch
    4. Test the water level switch
    5. Inspect the motor coupler
    6. Inspect the drive belt (belt drive only)
    7. Inspect under the washer for soot (clutch)
    8. Test the motor
    9. Inspect the pulley
    10. Test the transmission
    please rate my suggestion...
    Posted on May 22, 2009
    Joe Hogan
    • 10865 Answers
    SOURCE: washer will agitate but will not drain or spin in
    hello. I can help you. Your washer has two rather complex problems. Here are all of the possible things that could cause the problems you have:;
    If your washer won't drain, check these:
    It spins, but doesn't pump
    It doesn't spin or pump
    It pumps, but the water returns
    It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
    To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
    Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
    If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
    It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
    It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
    • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
    • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
    It doesn't spin If your washer won't spin, check these:
    It doesn't pump or spin
    It pumps, but doesn't spin
    It spins only with the lid closed
    It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
    • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
    • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
    • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
    • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
    • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
    • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
    • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
    • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
    Posted on Jun 07, 2009
    Assistance with rectifying as to why my LG top loader stops once it gets to the spin cycle. Can someone assist?
    Before the washer can start to spin it needs to drain the water from the drum. By you having to drain the water from the machine indicates that the drain operation is not happening. This in the majority of the cases is a bad drain motor.
    Aug 26, 2015 | LG Washing Machines
    My machine wont run, i replaced the drain pump and thermostat sensor.
    Depending on your model pushing soil level and spin speed at the same time then hitting the power button will start it in diagnostic mode from here out pushing start will check its features, door lock, low spin, high spin, pre wash, wash, bleach, softener, rinse, drain, spin...ext
    Jun 01, 2014 | LG WM2688HWM TROMM SteamWasher
    WASHER WILL WASH ON ALL CYCLES, BUT WILL NOT DRAIN OR SPIN ON EITHER CYCLE
    If the timer advances normally thru the spin and drain steps of the cycle you selected, than the problem that would cause neither spinning or draining, is the wash motor is not reversing. The motors is a two direction motor. It spins clockwise for normal agitation, but counterclockwise to engage the wash drum clutch and operate the drain pump. I would ask you to check for motor sounds at all during the spin and drain cycles. The pump reversing in the spin or drain cycles can be a function of the machine's lid safety switch, or if not the motor switch or timer contacts. The lid switch is first thing to check here, for sure! If the machine seems to stop running when it comes time to drain or spin, the lid switch is your best bet!
    Hope this helps.
    kcomp1863
    Jan 16, 2011 | Roper RAS8445KQ Top Load Washer
    WM2487HRM goes thru the wash cycle then gives OE error message. after drain tub with drain tube and reinsert drain filter, will happen again. if drain tub and unplug for 30 minutes, it will do spin only...
    Drain hose is kinked or clogged the pump filter needs cleaning .
    always turn machine off when working on it . and donot forget there is always water in filter .so put blanked or towels down.
    Feb 12, 2010 | LG WM2487HA Washer
    The drain/spin cycle always adds water
    It's normal if it just adds a little bit of water. It does this so your drain pump impeller doesn't run dry which could damage it. If it's filling right up, there could be a malfunction with the control board, the pressure switch or the inlet valve .
    You could try shutting off the water supply at the taps before you start the drain/spin cycle.
    Feb 08, 2009 | Whirlpool GHW9400 Front Load Washer
    Jun 09, 2008 | LG WFT1071TP Top Load Washer
    Clothes too wet upon cycle completion...
    Try reducing the amount of low sudsing detergent you are using. This can make the load too heavy and won't spin out. Remember suds have 3 parts, air, detergent, and water. The drain pump is designed for water, so if you see suds during the wash, it will be worst on warm and hot, then there is too much detergent, or is not low sudsing. I know Bosch reccommends HE, however HE liquids normally are not low sudsing, just High Engery. Also the Permanent Press cycles are always a lower spin speed. Hope this helps
    Jan 20, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
    Washing Machines Logo
    292 people viewed this question
    Top LG Washing Machines Experts
    Michael Thomas
    Michael Thomas
    Marvin
    Marvin
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
