Question about Pool & Spa
SOURCE: my kreepy krauly is moving at half speed and
Check your pump pressure on the suction side. If there is any air gap in your pump strainer pot (if you have a see thru see thru strainer cover) then you have a leak on the suction side. Auto matic cleaners need ample pressure for them to move. or you might need to backwask the filter check your pressure gauge. If none of these help its more then likely the gears in the cleaner. also check your cleaners hoses
Posted on Aug 16, 2009
SOURCE: KREEPY-KRAULY Ties itself into a knot while cleaning.
Solution:
We removed 2 portions of hose located at the Krauly end, and attached those at the filter end, then we took the 2 portions located at the filter end, and placed those at the beginning of the Krauly end.
Apparently the problem was that the 2 portions of hosing at the Krauly end had become "twisted" and continually enabled the Krauly to move in the knot tying direction. By replacing these 2 portions at the Krauly end with "un-twisted" portions from the filter end, this ended the twisting cycle.
The Krauly has been running for 48hours straight now without a single knotting episode.
If we see the knot tying direction beginning again, we will repeat these steps, continually replacing with un-twisted portions.
At 1st we thought we needed to purchase some new tubing, but we didn't have to, only needed to move around some hosing.
Posted on Jan 05, 2010
SOURCE: Hi my kreepy krauly wont stay flat on the bottom
Do you have any hose weights fitted to the kreepy hose? If you do,take it off and see if it makes a difference.Is this happening while the kreepy is operating?
Posted on Mar 27, 2010
SOURCE: My kreepy Krauly will start up and within 5 stops working.
If it is a year old, replace the flapper valve. Also check your water flow and make sure it is adequate. These units are subject to wear on the foot and flapper and these should be changed each season
Posted on Apr 14, 2010
Testimonial: "Great thank you for this info...I believe that I need to buy another type....too many problems with this type of cleaner."
SOURCE: Our kreepy krauly will not stay suctioned to the
Check for air leaks in your hoses, your pump or in the plumbing system. Also check for clogs in your pump impeller if you have any problems with your basket. Good luck.
Posted on Apr 24, 2010
Jan 18, 2014 | Pentair Kreepy Krauly Inground Automatic...
Jan 04, 2014 | Pentair Kreepy Krauly Inground Automatic...
Aug 04, 2013 | Pentair Kreepy Krauly Inground Automatic...
Apr 09, 2017 | Universal Kreepy Krauly In-Ground Pool...
Feb 11, 2011 | Universal Kreepy Krauly In-Ground Pool...
Dec 30, 2010 | Universal Kreepy Krauly In-Ground Pool...
Aug 13, 2010 | Universal Kreepy Krauly In-Ground Pool...
Jul 28, 2010 | Pentair Kreepy Krauly Inground Automatic...
Jan 03, 2010 | Pentair Kreepy Krauly Inground Automatic...
Aug 16, 2009 | Universal Kreepy Krauly In-Ground Pool...
592 people viewed this question
