Question about Ricoh Office Equipment & Supplies
Error code sc202 in mp c2004 ricoh - Ricoh Office Equipment & Supplies
Posted by LASY on
Waleed Ibraheem
    Habit-Forming:
    New Friend:
  • 60 Answers
Sc 202 is polygon motor: ON timeout error
Posted on Apr 17, 2020
1 Related Answer
Anonymous
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
I have a Ricoh MP C2500 and it shows SC202 error How do I fix this
Replace your polygon mirror motor or complete laser unit if you have one available. Replace this a.s.a.p as it can cause your BICU to pop. If your machine is already dead and you picked the code up on the web browser you need to replace the BICU as well. Do not replace the BICU without replacing the polygon motor. If you do you will pop the BICU again.
May 24, 2016 | Ricoh Aficio Mp C2500 Color Laser -...
Ricoh mp 1600 error 194 ricoh mp 1600 error code 194 how do I solve the problem
Having problems finding your error code. Here is a complete list of all codes for your printer: http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20MP1600
I do find the error code for a different Ricoh model (Aficio 1018).
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%201018
Please verify your model number and error code.
Apr 21, 2015 | Ricoh Aficio Mp-1600 Copier
INTERNET SETTING FOR SONY XPERIA C2004
Insert sim it'll automatically configure if not call customer care no 121 they will give manual setting
Sep 04, 2014 | Sony Xperia M C2004 4 GB Dual SIM White...
RICOH SPC430DN error sc202
sc202 is a polygon mirror motor. The most likely problem is that the motor has gone bad, and it will need to be replaced. Occasionally this error is caused by a loose or disconnected cable, but it is usually a bad mirror motor. You should contact your local service technician for replacement of the polygon mirror motor.
Nov 18, 2010 | Ricoh CL4000DN Laser Printer
Problem with the Ricoh mp c2800 Ricoh error code sc 672,
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
Nov 15, 2010 | Ricoh Aficio 1035 Copier
Error code sc202 on infotec isc615g
SC202 is a problem with what is called the polygon motor, It is the motor in the laser unit and has most likely failed.
Jul 14, 2010 | Ricoh Aficio MP 161SPF Color Copier
Aug 19, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
80 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
CheckitRight
CheckitRight
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
