SOURCE: My gas fire keeps going out soon after turning it
This problem is caused by a defective gas supply valve.
SOURCE: honeywell smartvalve flashing 6 times, pilot lit but burners won't light
Smatvalves of certain year were bad, check the module and see if its a bad one recalled, if not see the codes youmention for the brand its on.
SOURCE: Pilot will not kick on, TCO Switch is where?
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Thermal cut off located on front of combustion chamber door
http://waterheatertimer.org/images/Whirlpool-Resettable-TCO-20.jpg
gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
The flashing light 4 times indicates high water temperature has activated the over heat sensor, and that the only remedy is to replace the gas control valve/thermostat.
