Question about Taylor Health & Beauty
Taylor Body Composition Scale 5749FW User Manual
Posted by Suzanne Tuccelli on
Terry
  • Taylor Master
  • 11,377 Answers
Call or contact manufacturer.
https://www.taylorusa.com/contact-us/
Posted on May 06, 2019
5 Related Answers
Anonymous
  • 74 Answers
SOURCE: Taylor Scale 7532s - not working
This link allows you to trouble shoot directly with the company....I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
Anonymous
SOURCE: The instructions for the Homedics SC-540 (SC540)
I had the same problem. However, you can request its manual to customer service, [email protected]. I received the manual in a few days via email.
Posted on Mar 13, 2009
Anonymous
SOURCE: Tanita Ultimate Scale 2001 - no user manual -how to set it?
does your scale have an orange SET button and a button with a triangle (or arrow) below the display?
Try this... make sure the scale is turned off. (and you are not standing on it)
Now press the SET button.
2 arrows should appear on the display. use the arrow/triangle key below the display to make changes and the SET key to choose.
If you have the same scale as me, you are prompted to chose Adult/Child followed by Male/Female, and finally input your height in feet/inches by pushing the arrow/triangle key until the display shows the desired height.
Press SET to finish and step on the scale like you usually do. It will now show your weight followed by your body fat %.
Hope this helps you!
Jacob
Posted on Jul 14, 2009
rk_smith
  • 39 Answers
SOURCE: how do i program the taylor body fat scale
From the Taylor web site
http://www.taylorusa.com/faq-scales
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
Posted on Jan 21, 2010
Testimonial: "The website does not have a manual. Using 'search' or site map produces nothing. Another problem: scale reads only in cm and kg. Won't cycle to ft/lb."
pictureman4u
  • 132 Answers
SOURCE: taylor made r7 quad user manual
Here you go...you can find it at .....http://www.golf-finder.net/index2.php?option=com_content&do_pdf=1&id=294
Posted on Mar 16, 2010
How do you calibrate, it's a body fat scale, can't find model #?
It's important to find the model number to be able to find the correct manual. Below is a link to FAQ's about Taylor body fat scales.
If you do a google search for "taylor body fat scale" you will see a list of a few models. Examine each to see if one of them is the same as yours.
Taylor USA FAQs Scales
Searches related to Taylor body fat scale model number location
taylor body fat scale model 5741 manual
taylor body fat scale model 5761bf
taylor body fat scale model 5731f reviews
taylor body fat scale accuracy
taylor body fat scale 5731 review
taylor body fat scale athlete mode
taylor body fat scale readings
taylor body fat scale5758f manual
Aug 01, 2014 | Taylor Health & Beauty
I need a Taylor 5579 Body Composition Scale Manual
Check under your scale, mine had the instructions listed there
Feb 10, 2013 | Taylor 5568 Fat Scale Stainless Steel ()
Where do I get a manual ?
you can purchase a manual of Taylor 5599 440 Pound Tempered Glass Body Fat-Body Water Scale on ebay or in amazon...http://www0.dealtime.com/taylor-glass-body-fat-scale-manual/products
Apr 27, 2011 | Taylor 5599 440 Pound Tempered Glass Body...
I need an instruction manual for my taylor body fat scale #5568.
I posted the manual in my photobucket album here:
http://s1125.photobucket.com/albums/l587/landofnarnia/Taylor%205568%20Scale/
Amy
Nov 01, 2010 | Taylor 5568 Fat Scale Stainless Steel ()
Need manual for TAYLOR scale 5568 CAN'T GET IT TO DOWNLOAD/
I uploaded my manual for Taylor Scale 5568 into photobucket, you can find it at this link:
Sep 14, 2010 | Taylor 5568 Fat Scale Stainless Steel ()
How do I get A manual for model 5599 scale?
Taylor customer service would be able to send you a copy of the manual either by mail or email. Here is their number. 1-866-834-3905. Here is their website. http://www.taylorusa.com/taylor-support
I hope that helps :)
May 14, 2010 | Taylor 5599 440 Pound Tempered Glass Body...
Health & Beauty Logo
57 people viewed this question
Top Taylor Health & Beauty Experts
Marvin
Marvin
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
