Question about Dehumidifiers
What does the error code E9 on my hisense dehumidifier indicate?
Posted by Rusty Met on
Would like information on Hisense dehumidifier serial number: KH5Y9JF 0064?
Google (hisense)(KH5Y9JF 0064)(manual) without parens.
Aug 06, 2018 | Dehumidifiers
I have a Hisense dehumidifier DJ6A4JF0508 and need to clean my filter plz tell me how
Google (Hisense)(DJ6A4JF0508)(manual) without parens for instructions.
May 21, 2018 | Dehumidifiers
Why is my soleusair dehumidifier model GL-DEH-50 say F2
Pipe Temperature Sensor Malfunction.
1.
Unplug the dehumidifier.
2.
Check the surrounding area
for possible reasons for sud-
den temperature changes.
3.
Wait 2 hours before plugging
the dehumidifier back in for
normal operation.
4.
If the "Error" is still indicated,
please contact customer
service. Call 1-888-876-538
Soleus Air SG DEH 70EIP 6 Operating Instructions Manual Error Codes...
Jul 31, 2017 | Dehumidifiers
Frigidaire dehumidifier has a F2 error and will not operate
Hello - Typically error code F2 indicates a sensor failed has occurred on the dehumidifier. You may want to contact your manufacturer to verify if the part is available and can be replace. Some do, some don't. Also confirm if the unit has a limited warranty on such concern.
Oct 20, 2012 | Whirlpool Dehumidifiers
What does code AS mean - seems to be working fine.
Hello marilu scheck - Typically error code AS indicates that a sensor failed has occurred on the dehumidifier. You may want to contact your manufacturer and then a professional they suggest to have it repaired.
Oct 03, 2012 | Frigidaire FAD704TDP Dehumidifier
Have a year old lg dehumidifier and a code of 01 appears in the window and will not start.
The error Code 01 indicates that either the air intake filter is dirty and needs to be removed and cleaned and/or the water collection bucket is not installed properly. Turn the unit OFF & unplug it, before attempting any service work.
Hope this helped you & thanks for choosing FixYa.
Sep 12, 2011 | LG LHD45EL Dehumidifier
My dehumidifier gives the code of 01 in the display window and will not turn on.
Error Code '1' indicates that the air intake filter needs to be removed and thoroughly cleaned. be sure to turn the unit OFF and unplug it, before removing the filter. Never operate the unit without the filter in place. Doing so, could cause damage to the unit.
Hope this helped you and thanks for choosing FixYa.
Sep 08, 2011 | LG LHD459EL Dehumidifier
Indicator reads PF.cannot get it to run,any ideas
Your model Delonghi Dehumidifier has been retired. Therefore, no online manual is available. However, if you contact Delonghi Customer Support (1-800-322-3848), they can furnish one and answer the question about the PF error code at the same time.
Thanks for choosing FixYa.
Aug 11, 2011 | DeLonghi DEC 180 E Dehumidifier
We have a DAnby dehumidifier - model SHCC6026. It keeps showing an E7 error. Is there a simple solution to the problem?
The E7 Error Code, indicates that the front cover of the unit it no properly in place and making contact with it's removal sensors. Remove and reinstall front cover properly. Be sure to turn the Master ON/OFF Switch to OFF and unplug unit before attempting this.
Hope this helped you solve the problem.
Jun 22, 2011 | Danby DHCC6020 Dehumidifier
Unit will not run.
Error code 01 - unit has a sealed system leak; most warranties are 5 years.
Dec 30, 2009 | Kenmore 54701 Dehumidifier
Dehumidifiers Logo
390 people viewed this question
Top Dehumidifiers Experts
jasbo
jasbo
Marvin
Marvin
Are you a Dehumidifier Expert? Answer questions, earn points and help others
