Question about LG WM2016CW Front Load Washer
I have an error code of IE front load washier model: WM2016CW how do i fix this problem.
Posted by James Spitz on
Stephen Taylor
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Not enough water getting in your machine make sure your inlet hose isn’t kinked or the water pressure hasn’t dropped.
Posted on May 06, 2019
2 Related Answers
omaharox
Mike
  • 166 Answers
SOURCE: IE error code
IE. is inlet water valve error.
Make sure someone did not turn off the water to the washer!!!!
Remove fill hoses and check filter screens on washer and fill hoses and clean if needed.
If problem continues water valve may need to be replaced.
Posted on Jan 16, 2010
Anonymous
SOURCE: LG Model WM2016CW Front load washer is 1 year old.
Same thing happened to me
I freaked out
Then I emptied the water basin, on the front of the machine near the bottom. then it started up and worked
Posted on Aug 17, 2010
How do I fix a loose or locked up drum that generates LE errors?
you sure it is not and upside down 'F' instead of an L? that would be a hall sensor(motor position sensor) error. easy fix. check out appliancepartspros.com or repairclinic.com for both parts and videos that show how to repair. very easy with common tools. about 20-30 minutes. basically take back cover off, remove motor cover, remove stator, replace part.
Aug 30, 2015 | LG WM2016CW Front Load Washer
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 02, 2015 | LG WM2016CW Front Load Washer
How do you fix the rear tub spindle on an lg wm2016cw?
If its the main drum bearings gone then this will entail a complete strip to access them. The parts are available online, just have your serial no, model etc ready and trawl through various web appliance sites to find the best price. You will need a fair amount of mechanical / DIY knowledge to carry out this task. There are lots of parts and electrical connections.
Aug 05, 2014 | LG WM2016CW Front Load Washer
Error PE on model wm2016cw, is this an easy fix?
Error Code PE mean Pressure sensor Error code
Check wiring connection to the pressure sensor; to solve it replace pressure sensor. The sensor repair is simple and straight forward.
Additonal details could find in this link: LG_Knowledge_Base
Hope this helps.
Aug 02, 2011 | LG Washing Machines
IE error code
Jan 16, 2010 | LG Washing Machines
WHY MY WHIRPOOL WASHIER IS NOT SPINNING OR MOVING
Is there any error codes? Do you have any lights coming on the front display?
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG FRONT LOAD WASHER ERROR CODE IE
LG has general error codes for all there appliances and the "ie" error code is for the water supply. You either have a kink in your hose, water vavle shut off, or the bad problem your pump is bad.
Jul 30, 2008 | LG WD-1045FH Front Load Washer
Figidaire Fron Load Washier
check that switch for electrical connection. Perhaps a wire came off.
Jun 06, 2007 | Frigidaire GLTF2940ES Front Load Washer
LG WM2016CW Front Load Washer Logo
134 people viewed this question
Top LG Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
