Question about Dehumidifiers
I just have had my new dehumidifier running since Friday and when started the humidity said 60,went down and checked it today and it still says 60,I have it set for 40,is this unusual after two days?
Posted by Sharon Serafin on
Vernon Taylor
  • 6,555 Answers
If your dehumidifier is working it will be extracting water from the atmosphere, into a container that will or should need emptying fairly regularly.
If it is working ok it isn't necessarily going to significantly reduce the humidity in the room as most rooms are connected to the outside world in a number of ways...
Posted on May 05, 2019
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Dehumidifier Compressor is not working
this unit is very simular to an air conditioner except it has a humidistat instead of a thermistat.. if your handy with a continuity tester unplug the unit find the humidistat and check to see if its open or if its good then call the company at 1 800 322 3848 or contact the web site at [email protected] Good Luck
Posted on May 31, 2006
Marty marty
  • 883 Answers
SOURCE: LG Dehumidifier Not Working
the freon has leaked out, must be replaced.
Posted on Jun 06, 2007
Anonymous
SOURCE: Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
Posted on Nov 13, 2008
Anonymous
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
Posted on May 02, 2009
Anonymous
SOURCE: The dehumidifier is running but very little water
I have the same problem, just started it after not using it for the winter and it runs and runs and no water. I believe the coolant has leaked from the sealed system and there is nothing you can do. I've had it for 1 year and it has a 5 year warranty. I know from experience, this is the 3rd dehumidifier that I have had this problem with, all different brands. Call for service, I am betting you have not had it very long.
Posted on May 09, 2009
Dehumidifier does not reduce humidity.
Good Afternoon Miguel,
I understand that your Frigidaire dehumidifier, model# LAD704TDL, is not reducing the humidity, due to the coils constantly freezing up. I also see that it is located in good temperatures and in a good position. I suggest contacting the manufacturer directly. They should be able to point you in the right direction to having your appliance fixed. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire Dehumidifier LAD704TDL
My Goldstar dehumidifier model DH304 runs,but fails to pick up any water
If the room air is less than the set air, then there is no water in the bucket, because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water.
Other things that can cause problems: 1.Check to see if the air filter is dirty and/or blocked. 2. The room temperature might be too low, (below 60 degrees Fahrenheit ) 3. Check to make sure that there is no obstruction to the unit that might be causing poor airflow circulation.
Hope this helps you to troubleshoot & solve the problem.
Apr 28, 2011 | Goldstar DH304 Dehumidifier
My dehumidifier runs, but no water is collecting. Humidity in the house is about 57%. The unit is only 3 months old.
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 01, 2010 | Kenmore 5230 Dehumidifier
When do you use the dehumidifier?
In areas with poor circulation and humidity over 80%.
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 28, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
My 320 is powered up and running but is not collecting any moisture
low outside temp means low indoor humidity
Dec 22, 2009 | Amcor MD250 Dehumidifier
No water in Dehumidifier
1) low outside temp means low inside humidity
2) If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
Dec 20, 2009 | Dehumidifiers
My challenge dehumidifier runs ok but does not collect any water , whats the problem?
Dec 20, 2009 | DeLonghi Dehumidifiers
Moisture not collected
low on freon is the compressor running?
Jun 18, 2009 | DeLonghi DE400P Dehumidifier
No manuel, do not know how to work
Hi Journeay,
The dehumidifier is telling you the humidity in your house is 45-50 % so it will not run until the dehum thinks it is over 60%. When you set a humidity it will show the setting then it will tell you the humidity in the house. Sometimes they are wrong, and somtimes the humidistat goes bad. I would suggest setting the dehumidifier lower than the 45-50 and see if it comes on. This time of year the humidity is usually low depending on your location. I have already put mine away for the winter. Please let me know if you have any other questions and I really hope this will fixYa. If not just let me know.
Mike
Sep 30, 2008 | Haier 45-Pint Dehumidifier
Take cover off. First check the fuse on the circuit board. If it's blown replace it. That should get the motor running, the motor might be or is going out. If the motor is bad you'll have to replace the motor. If the fuse is good and the motor is good, unhook the wires on circuit board that go to the humidity control switch. If the unit comes on with the humidity control switch unhooked, you'll have to replace the humidity control switch. Sears has them for about $11.50. Hope this helps.
Sep 13, 2008 | Goldstar DH304 Dehumidifier
Dehumidifiers Logo
147 people viewed this question
Top Dehumidifiers Experts
jasbo
jasbo
Marvin
Marvin
Are you a Dehumidifier Expert? Answer questions, earn points and help others
