Question about Boating
I have a Simrad AP26 autopilot for my offshore boat that keep going into Test Mode when I turn it on.
Unit turns on and screen goes into Test Mode and then to a data page with HW Rev #'s,Temp #'s, Volt #'s Kurs # then switches to screen Lysnivia #'s and other screens with Norwegian town names. Can send pictures What should I do to fix?
Posted by Jeff Osborn on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: dmr e85 will not start up
I have discovered my E85 to have an inadequate power supply. I took the lid off, and used an ancient computer power supply to power the HDD. Since then I have not had a problem with it cutting out dead and self checking on startup whenever I tried to hi-speed access (including dubbing, finalizing, viewing Navigator etc on the DVD.) It does not have enough power to supply every component during peak actions, and just cuts itself out. But not now!
Posted on Feb 25, 2008
Anonymous
  • 176 Answers
SOURCE: toshiba satellite laptop comes on and stays at windows xp page
If Safe Mode doesnt work then you may have to do a "repair" of your O/S. Place your Windows XP CD into the CD-Rom drive, reboot and once you see the options if you want to Install or Repair - choose Repair. This option will make repair to your O/S and for safe mode.
Once repair is complete do a complete Anti-Virus and Spyware scan of your Hard Drive. If you can boot into Safe Mode to run the ani-virus much better.
Posted on Dec 30, 2008
Radoslav Segaric
  • 43 Answers
SOURCE: Problems talking to autopilot
I think you use the NMEA output to the autopilot .
The plotter shows you only when you have a seatalkconection with a Raymarine autopilot on you Plotter
Posted on Oct 22, 2009
Anonymous
SOURCE: Simrad AP 11 Autopilot control head
I happen to have an ap11 head unit in good condition, please contact me.
Posted on Nov 08, 2009
TechnoMarine
John Barry
  • 132 Answers
SOURCE: Testing Simrad Autopilot RPU160 Reversible Pump (21118237)
yes, hook it to 12V it runs, reverse wires it runs opposite it will spit oil, watch out! shoulda coulda left it in place and tested with jumper cables or battery if pump is bad 1 find out why your boat eats pumps 2. call me, i have it in stock for less than you paid before (most likely) 3. you can replace the electric motor without disturbing the hydraulics!!!
847-746-0100
Posted on Jan 16, 2010
Problem: Autopilot does not engage. This is a new problem as it was working quite recently. Model: Simrad NSE8/AP24 with AC42 Autopilot Computer. Attempts to engage the autopilot result in an...
jimtippettau:
Which drive are you using with the AP24, is it just a hydraulic pump on a powerboat, like our RPU80, or is it a hydraulic linear drive (like our HLD-2000) or draglink drive (like our DD-15) on a sailboat?
Mar 24, 2011 | Simrad AP24 AUTOPILOT DISPLAY UNIT
I have a Simrad hydraulic drive HLD2000L autopilot on my boat. I can not find the recommended ISO VG 32 oil. Are there any substitutes that can be used until I find he correct oil? PS I am in the...
International Standardization Organization (ISO) established a viscosity grading (VG) system for lubricants. According to the system way lubricants are designated by the letters ISO followed by a number equal to the oil viscosity measured in centistokes at 40°C (104°F): ISO VG 32. Any atf, thf, stou, ps- fluid or aw32 hydraulic oil. Visit the next link and look for the Hydraulic Fluid Cross Reference Chart for hydraulic fuild brand reference: http://www.hfifluidpowerproducts.com/Pages/Hydraulic-Fluid.html
Mar 04, 2011 | Simrad AP24 AUTOPILOT DISPLAY UNIT
Oct 28, 2009 | Simrad Boating
847-746-0100
Sep 13, 2009 | Simrad Rpu160 Reversible Pump 21118237
Boat on screen does not point the direction the boat is going e-80 series also chart will not go course up or heading up like the radar does unit is set in relative motion mode
The direction of the boat symbol is depending on the compass course from the autopilot. You will see that your GPS course (COG) and magnetig heading on the autopilot differs. Solution is to calibrate autopilot compass. Will advice you to not use course up, stick to north up or heading up.
Sep 08, 2009 | Raymarine C80 GPS Receiver
Need instructions for simrad tp32
when hooked to a chartplotter, it will go to the waypoint that was marked as a goto on the plotter.
Mar 31, 2009 | Simrad Tp32 Autopilot Up To 39'
Simrad ac10 current overload
Normally this is the electric motor causing this problem. Just went on a call and had the same thing. Checked voltage coming from the AC unit to the motor and had 12 vdc then put a new one in it's place and it solved the problem. You don't have to change the pump portion, just change the motor itself. Indeed you will have fluid leaking but many times it's better than plumbing in a new pump.
Feb 18, 2009 | Simrad Ac10 Course Computer
Simrad Autopilot won't turn on
Try and turn on the unit at the J300-40 pcb by using a test light one end to gnd and going to the ap35 interconnect and touch the test light to each pin or until you hear the unit start up.
Dec 19, 2008 | Simrad AP35 GPS Receiver
Boating Logo
148 people viewed this question
Top Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
