Question about Braun Health & Beauty
I can't seem to get my Braun thermo scan to take my temp. What an I doing wrong.
Posted by VICKY HOGENES on
1 Related Answer
Anonymous
SOURCE: how do I replace the
Simply press the small recessed button (a small triangle is pointing it ) directly above the battery door with something slender like a ballpoint pen or a toothpick, while pushing the battery door down, away from the thermometer.
Posted on Mar 19, 2011
How to change thermo from C to F
Here is a link to the manual. Follow directions on page 10.
http://braun.kaz.com/files/IRT3020GB,%20F,%20E%20%28USA,%20CDN,%20MEX%29.pdf
4helpful
2answers
How do I replace the battery in my thermo scan plus ? cna't seem to figure it out Help I need it as my son is ill and the doctor keeps asking for his temp?
I have the same problem where my honeywell cm921 room thermostat never turns off the central heating. If I set my off temp really low will this solve the problem, but if its really low does this become the...
It's either because the thermo sensor is faulty or the location is wrong. Try setting the temp one degree above room temp and see if that works, if it does it's a location issue. The thermo should be close to the centre of the house, not near an outlet or the RA vent & not in a breezeway or other heatsink, at approx 1.5m above floor level.
3helpful
3answers
Radiator fan not stopping even when i turn off the car and remove the keys. this is leading to battery drain
Radiator fan is supposed to start working after the temp reaches a certain limit. And it is supposed to run til the temp reaches a certain lower limit. So when you switch off the engine and walk off the fans must be running to cool the water to that lower limit. Unless you seen that it runs well past that and does not stop at all. Does it start running when you start the engine? And runs throughout the time the car is running, which it should not. The relay seems to be out. It is this relay that controls the running of the fan. or the temp gauge. If the temp gauge is giving wrong temp then the relay has to keep working. Please check both, the relay and before that the temp gauge.
1helpful
1997 Honda Accord cooling problem.
Most Hondas and modern car fans can and do run at will. 215 on a scan tool is just reading the sensor and variation is ok. A temp gun is more accurate. Ill bet your gage is still normal. I have a honda and the fan runs at times when I get out. Normal
Engine running to cool
Replace the thermostat. If thermo is stuck open, coolant only heats up when there is no flow over radiator(idle) and then cools down when driving. Also, check coolant level, same response as stuck thermo.
Kenmore side-by-side with thermo switch problem?
Acting like a bad thermostat, One thing to check is make sure compressor isnt overheating. If really hot you could have a relay problem on compressor.
Health & Beauty Logo
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Joseph Hoffmann
reference30
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
