SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
SOURCE: green light turns red and red light blinks 4 times
Replace the Main Power Supply inside the TV.
SOURCE: 2 red and 2 green light are blinking!!!
I have this problem also and I just got it back from microsoft. I sent it in for a disk drive repair cus it wudnt read my disks and i just got it back and this happens. I didnt tamper the system or anything and it was still covered by warranty but they are saying in a letter that was in the box that something was no covered on the warranty for something. Help???
