It is a Pfister bar counter top faucet.
If you tried using a typical 1/2 to 3/8 faucet connector such as https://www.homedepot.com/p/3-8-in-Compression-x-1-2-in-FIP-x-20-in-Braided-Polymer-Faucet-Connector-B1-20A-F/100459572, and it didn't work then ignore this answer, else...
Plumbing pipe size can be misleading due to the fact the pipe diameter is based on outer diameter and the inner diameter varies with wall thickness. To determine standard pipe diameter you measure the outer diameter and subtract 1/8".
The typical 1/2 inch pipe has an outer diameter of 5/8" and like wise a a 1/4" inner diameter pipe is a 3/8". So likely the typical faucet connector is correct. But you may have something unusual so FYI.
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
SOURCE: can i connect a dishwasher to the hot water pipe??
In my opinion you always connect to the hot water unless there's some compelling reason not to like your dishwasher's manual says to connect to cold. Your dishwasher will heat up whatever water you have connected it to, but since you have a tank of preheated water already sitting in your water heater you should use that.
The "resin in the water softener" example, I think, makes no sense since your dishwasher will heat up the water to something like 160 degrees Fahrenheit no matter if the input is cold or hot...
SOURCE: No cold water
Anti Scald Valves have an adjustment under the handle (remove handle) to allow so much hot water in no matter how far handle is turned. Its possible that the adjustment is set to allow only hot water in, this of course defeats the purpose of anti-scalding. Check to see if you can adjust this back. Good Luck have a Great Day. Please give a 4 THUMBS UP if this free answer was of any help.
SOURCE: Problem with valves in Grundfos hot water recirculation system.
Yes, you need to replace it.
SOURCE: I have a kenmore elite H3 washer. The cold water
Check the inlet valve solenoid wires for resistance with an ohms meter. The cold and hot solenoids should have close to the same resistance. My washer had a weak solenoid causing the hot water valve to close after 4 or 5 seconds. While checking the solenoid wires for resistance with the ohms meter, I noticed the cold side had 51 ohms but the hot side only 8 ohms. Hope this helps.
