Question about Furniture
Hi I’m after king single mattress but I need to use both sides.
Posted by Di walsh on
ray gallant
    Top Expert:
  • Furniture Master
  • 69,169 Answers
THEY DO NOT MAKE A KING SINGLE
Posted on May 05, 2019
2 Related Answers
phil
  • 27 Answers
SOURCE: What are the disadvantages of a single sided mattress?
I personally find the single sided mattress more commutable to sleep on.
A single sided mattress is not to be flipped not like double sided mattress.
Flipping the single sided mattress will cause the comfort layers to redistribute and will maximize wear.
Posted on Jul 18, 2012
snoozebeds12
Snooze Bed
  • 100 Answers
SOURCE: What is the difference between a king size (eastern king) mattress and a California king size (western king) mattress?
We recommended purchasing a king size bed if you are unsure on what size to buy next! You can view our entire range of beds via the link https://www.snooze.com.au/collections/beds/king
Thanks
Posted on Nov 29, 2018
Why only one side get hot
These are made with a wire in them that heats up. Yours probably has a wire for each side, and one has gone bad. DO NOT continue to use it. I suggest you take it to a qualified repair technician or replace it. It could cause a fire or electric shock.
Dec 07, 2015 | Sunbeam California King Arlington Heated...
I have a Rest and Relieve Therapeutic King Heated Mattress Pad that I have lost the remote control for. where can I purchase a replacement remote?
You should try to contact the supplier of your mattress cover. If they have a website, you can check their website to check if they provide the separate remote for that particular mattress. Even if they don\'t, you can contact them asking the solution.
Jack
Jan 21, 2013 | Sunbeam Bedding, Rest and Relieve...
How often should I turn/rotate my memory foam mattress?
Memory foam mattresses should not be flipped at all - they only have memory foam on one side.
Jul 25, 2012 | Furniture
I found you a great comparison chart that shows the differences between the two types of mattresses.
chart
California King Size
King Size
Usage:
California King Size beds may be found either in the master bedroom or for exceptionally tall kids.
King size beds are usually found in the master bedroom.
Cost:
California King Size beds cost roughly the same as regular king size beds.
Since a king size bed is larger, it is more expensive and mattresses in this size may also cost more compared to queen beds.
Width per person:
The width available on a king size bed would be 36 inches per person if two people are sharing it.
The width available on a king size bed would be 38 inches per person if two people are sharing it.
Space economy:
A California King size bed is larger than a queen size bed. It is longer but narrower compared to a regular King Size bed.
A king size bed is fairly large compared to the queen or full sizes.
Length:
84"
80"
Width:
72"
76"
Surface area:
6,048 sq. in.
6,080 sq. in.
Chart was taken from: http://www.diffen.com/difference/California_King_Size_vs_King_Size
Why other leter n ke board not function
its just dirty contacts if you can open your keyboard, clean contacts with non rubber eraser like the ones used by engineers and draftsmen. also include the rubber contacts under the keys
Jul 25, 2012 | Acer Computers & Internet
Are waterbed mattresses the same size as conventional mattresses? I'm looking to get a waterbed, but I'm slightly concerned about space.
The sizes vary slightly. Waterbeds are sized as follows: Single is 48" X 84"; Queen size is 60" X 84" and King size is 72" X 84".
Jul 24, 2012 | Furniture
What's the size of the common mattress?
A children mattress is mainly between 38 on 75 inches.
An adult single mattress is around 53 on 75 inches.
A couple king size mattress is around 76 on 80 inches.
Jul 18, 2012 | Furniture
What are the different sizes of mattresses?
I found this chart that explains thedifferent mattress s available:http://www.sleeptrain.com/mattress--chart.aspx
May 29, 2012 | Furniture
What are the dimensions of a King Size Bed?
I found this great diagram from United Mattress Warehouse that may be helpful!
Furniture Logo
140 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
