Question about Toys
Replaced e300 batteries, now runs sporadically, cute in and out. Not a problem before.
Posted by Jim Morris on
My E300 runs for 15 minutes get's slow rests then runs again what wrong???
it will run slow for 40 mins at a slow speed, after 15 mins of running fast, the batteries get too hot
Apr 11, 2016 | Razor E300s Electric Scooter With Seat
E300 razor scooter would run then stop then run then stop. Is it possible it is the batteries even if they read 12 volts on a meter?
Well how long between runs and stops? Batteries can be bad even with 12+ volts on a meter with no load. Is the on/off regular like the controller cycling, or irregular like a damaged wire? The hall sensor in your throttle could be causing it, if it's loose or not working properly. You can open the throttle with a socket and a screwdriver. Check all wiring, check the batteries under load. If you say more about the frequency and duration of the stops and run periods it would help.
Jun 16, 2015 | Razor E300 Scooter
E300
Im not sure I understand your question. The E300 runs on 2 batteries at a time and they recharge in the unit. To replace them clnnect one + to the other - and the remaining + and - to the unit.
Sep 08, 2014 | Razor E300 Scooter
E300 electric scooter battery,
The scooter uses batteries specifically designed for deep discharge applications. If your new batteries are not lasting then they may only be suitable for standby or backup type applications like for your house alarm system or garage door opener when the mains power goes out.
Mar 19, 2014 | Razor E300 Scooter
Do UPG 12 volt 7ah batteries work as good as "RAZOR BRAND" Batteries?My scooter is an e300.Do you know if by chance,the e300 scooter needs razor batteries only?I got generic ones,and they are terrible
No. We get batteries from a local supplier and they work just as well. are by far the most common problem with razors because people dont keep them charged.
E300 , replaced both batteries , now charger light stays green although just plugged in to new batteries for first time. What is it now ?
This is most likely the control module.It can cause this.I had it happen before :) hope this helps.Buy one at www.razor.com or on ebay.
Feb 06, 2014 | Razor E300 Scooter
Razor E300 runs but very slowly
get some new batteries.
yours are worn out.
Mar 29, 2013 | Razor E300 Scooter
Hi there,My girls Razor E300 is a year old wont fully charge...
My guess is the batteries have gone bad. They only last about a year before they need to be replaced. You can buy them fairly cheap off of Ebay.
Jan 04, 2013 | Razor E300 Scooter
I replaced new battery but still the scooter runs slow
The Razor E300 electric scooters are battery operated scooters and can run at 15 miles per hour. This is enough to produce the best fun for kids while on their free time. It's a quiet worker, and with that speed, you won't get scared of the child going too fast to be prone to accident. Yet, it is still good to take precautions. Let the kid wear a helmet, foremost, because this can protect the head should accidents happen.
Your scooter may need new batteries, or a controller. To check these components functionality you will need a volt meter. Check the current coming out of the batteries, check the current going into the batteries and both should read in the 12.5-14 volt range. If your charger, ore the charger connection is faulty you will need wiring, or a charge port. If your batteries are faulty, you will need batteries. Check your controller with a volt meter, or a test light to see that all connections are secure and the controller is functioning properly. If you need parts or repairs done, you can visit this Electric Scooters Parts Store Online with "Find a Repair Shop" feature.
I hope this helps; remember to rate this answer.
Oct 04, 2010 | Razor E300 Scooter
Where is the battery on e300 97' model
The C- Class (202 chassis) has the battery in the trunk, the E- Class (210 chassis) with the round head lamps has it under the rear seat.
Jan 12, 2009 | 1998 Mercedes-Benz E-Class
Toys Logo
146 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
