Question about The Watches
How do you get the back of a swarowski watch to change the battery
Posted by Dawn Duckmanton on
Tom Chichester
    Top Expert:
  • The Master
  • 55,379 Answers
You take the watch to a jeweler
Posted on May 04, 2019
How do you change battery
How to Change a Watch Battery with Normal Tools - YouTube
? 9:18
https://www.youtube.com/watch?v=gFmV7NIjVsw
Sep 1, 2011 - Uploaded by RichsMethods
Hello, here's a video that provides straightforward, easy to follow steps on how to change a watch battery. I ...
Replace Your Watch Battery Yourself With Household Tools ...
? 7:32
https://www.youtube.com/watch?v=L4Y7pDonkmk
Aug 15, 2013 - Uploaded by tsbrownie
How to replace a watch battery yourself using common household "tools". Covers both snap back and screw ...
How to Change a Watch Battery: 13 Steps (with Pictures ...
Dec 15, 2015 | Watches
How to change battery on disney accutime watch and what type of battery is needed. Thanks!
You won't know what battery it takes until you pop the back off and see what battery is in there. I've opened two identical watches and on the inside they had different movements that required two completely different size batteries. The trickiest part with Disney watches I've done is if it's musical, getting that to reset. Be careful, a lot of people don't realize how easy it is to mess up those tiny little parts, get dust in there, put the back back on wrong etc...
Feb 04, 2014 | Watches
How do you take the back of a wrist watch off so you can change the battery
The Proper way is with a "watch case wrench". They can be purchased for a few dollars on Amazon and E-bay. In most cases unless you are changing many watch batteries the best option is to call around to local jewelers and pawn shops and ask how much to replace a watch battery. In my town it ranges from $30 to as little as $5.99 battery included.
Dec 14, 2013 | Meco 2PCS Watch Case Back Opening Tool...
Changing battery in Michael Kors watch
back off, remove old battery, install new battery, back on
Sep 21, 2012 | Michael Kors Chronograph MK5198 Watch for...
How do you change the battery in a black dice flow watch
You need to open watch case back using appropriate tools. There are two batteries in this model - one for each watch movement. Unscrew/un-clip battery contact. Memorize polarity (+ and -). Take the battery to your nearest watch battery shop or watch repair shop and buy the same one. Fit new battery back in watch (remember polarity!). Fit back contact as it was. Close the watch case back. Set the time. Done.
Feb 25, 2011 | Black Dice Industries BD04101 Flow From...
How to open the back of Kenneth Cole KC3434 watch to change the battery?
BASIC WATCH BATTERY CHANGE
Get a replacement battery for your watch. Some watches have the battery information stamped on the back plate. If yours doesn't, you'll have to wait until you've removed the old battery to see what kind of replacement watch battery you'll need.
Lay your watch face down on a non-scratching, non-skid surface. It may help to clamp the watch to the surface.
Remove the back from the watch. You might be able to pry it off with your fingernail, but you'll probably need a stiff, thin tool like a knife or screwdriver. You can also buy watch repair kits, which have the perfect tools for the job. Check the watch back for a small notch to insert your tool, but not all watches have these.
Remove the battery from the watch once the back is off. You might need to tip the watch over to let the battery fall out.
Insert the new watch battery into the proper space, first double-checking its size against the old battery to make sure it will fit. Press lightly into place.
Replace the back on your watch. Make sure you press firmly to get the back seated snugly.
If this doesnt work, then take to a local jeweler/watchmaker who is equipped with the right tools to assist you.
Best regards.
Aug 17, 2010 | Kenneth Cole KC3434 Wrist Watch
Crystals framing my Haurex watch face are falling out.
Hi, im a jeweller myself. The problem with jewellers and crystals is simple. Its a lot of work to replace something that doesnt cost a lot to buy (the crystals, not the watch). Swarovski are a commonly known producer of crystals, but you will probably find that simulation gemstones such as Cubic Zirconia are commonly used in newer watches.
I specialise in gemstone setting, and can also work with simulation stones and crystals, but it takes much longer to reset stones into a stainless steel watch case than into gold or platinum so the labour costs are much higher.
It depends how much the watch is worth as to how much you spend on repairs.
Hope this helps
Dec 18, 2008 | Haurex 27473-031-00 Wrist Watch
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Mar 15, 2007 | Fossil University of Oklahoma LI2282 Sport...
Watches Logo
566 people viewed this question
Top The Watches Experts
 Larry
Larry
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a The Watch Expert? Answer questions, earn points and help others
