Question about Xerox Office Equipment & Supplies
I have a machine xerox wc 7225 which writes: wait ... the settings are in progress. How to solve this problem?
Posted by Philippe Amuzati on
1 Related Answer
Rick Kasper
  • 2072 Answers
SOURCE: Our xerox workcentre 4150 is
You will either have to take off the back cover and remove the memory battery. One of those round lithium batteries and reinstall it or go to xerox.com, download the newest level of firmware and load it to the machine.
You may also want to try turning the machine off. unplugging the hard drive and see if it works like that.If it works without the hard drive replace it. If all those steps do not work replace the main board.
Posted on Aug 13, 2010
Hi! How to fix error code 092-315 for xerox 7225?
That is a black drum atc failure. First try to replace the black image drum and if that doesn't resolve it can be the MCU Board.
Mar 07, 2016 | Xerox Office Equipment & Supplies
Xerox WC 7225 error 303.316.00 - how to solve?
Your best bet is to go to the Xerox.com website and follow the troubleshooting guide.
Good luck.
Feb 21, 2015 | Xerox Office Equipment & Supplies
I have Xerox 5016 model Photocopier , I am getting Error U4 ,some technican from Xerox advised that it can be solved by pressing some button ..? If anyone can support would be a great help.
Enter into the diagnostic mode.Press 50 then green button,press 20 then green button,press 00 then green button.Switch off the machine & Switch On.
Jan 15, 2011 | Office Equipment & Supplies
Our xerox workcentre 4150 is stuck in a self test mode. We have turned off the machine and unplugged it several times, and it keeps going back to the message Please wait....Machine self test in progress....
Aug 13, 2010 | Xerox WorkCentre 4150 Black and White...
Reset fault code 010-348 xerox 3535 copier i have replace the fuser with new
wait until the machine is in the 'Ready' state, then on the Control Panel, select [9] and [AC] simultaneously. A message will be displayed asking if the Fuser Cartridge was replaced, select [Yes].
Jan 01, 2010 | Xerox DocuColor 3535 Copier
Double image is printed on one page, overlapped on Brother 7225
It sounds like a piece of paper is wrapped around the fuser roller. Look in the rear of the machine with a flashlight.
Jan 22, 2009 | Brother MFC-7225N All-In-One Laser Printer
Reset Xerox Copier Machine model No. 5825
your copier should be displaying a fault code, different codes need different reset codes - be specific
Jan 05, 2008 | Office Equipment & Supplies
29 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
