Ice forming in freezer
Look inside the refridgerator and find the drain, make sure it is clear and if neccesary put a few drops of drain claner fluid into it.
Posted on May 04, 2019
SOURCE: Water collecting in refrigerator and ice collecting in freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 15, 2008
SOURCE: Maytag Model MZD2766GEW iced coils
This sounds like a defrosting problem. There is a defrost timer, a heater element, and a therm-o- disk thing that shuts the heater off when the frost is melted. These are the things to check, but it's usually the heater that is burnt out.
Posted on Jul 23, 2008
SOURCE: MY MAYTAG REFRIGERATOR
remove back panel inside freezer and there is a tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off with a hairdryer and follow up with hot water till it flows waay freely
Posted on Oct 02, 2008
SOURCE: leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Posted on Jul 03, 2009
SOURCE: GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Posted on Oct 22, 2009
Oct 23, 2017 | Refrigerators
Aug 21, 2011 | Maytag MZD2766GES Side by Side...
Apr 22, 2010 | Refrigerators
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
May 07, 2009 | Refrigerators
Apr 15, 2009 | GE Refrigerators
Mar 26, 2009 | Refrigerators
Feb 23, 2009 | GE Refrigerators
Sep 17, 2008 | Sub-Zero Refrigerators
Jan 20, 2008 | Freezers
65 people viewed this question
