Pls check that model number........the problem description does not match that of a 1999 crt proj tv.........I believe yours is a newer lcd projection around 4 or 5 yr old?? Lamp light flashing on any brand is indicative of the lamp not lighting . The lamp is the most likely cause,but the ballast board can cause this as well..................you should see an access door refer to owner book of the correct model and you can replace yourself...........it may cost around $200 and avaiolable at encompass parts .com Hitach distributor
It may be. I have replaced the lamp in my sony 3 times. Look for dlp lamps online and enter in your tv model. There are instructions online on how to change it yourself. They also show you in your manual. The power light should blink red indicating bulb failure. Read your manual. Hope that helps
The POWER/STANDBY (red) indicator flashes three times If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing) A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing) A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Replace the lamp. In rare cases, the lamp power supply or lamp ballast may also need replacing. But, replace the lamp first, and use an original Sony lamp not a cheap aftermarket replacement. If this helps, please be sure to rate the fix! Thanks!
usually the lamp light blinking red is an indication that the lamp has malfunctioned. Try removing the lamp housing and reinsertng it. if that doesnt help you will need a new lamp or ballast. most likely the lamp
