Epson R1800 Printer turns OFF
Every time I want to print a document or even perform any maintenance printing the R1800 simmply turns off. No flashing errors pop-up.
What could this be? Is there any way to Reset the EEPROM?
Thanks
Posted by joelrodz on
  • 3 more comments
  • joelrodz
    joelrodz Aug 07, 2009
    There is no adapter per say... it connects directly to a socket on the wall.
    It's not a Power issue since the Printer turns on properly and those its routing check up without a problem. Both my Mac and PC recognizes the printer and properly show Ink Cartridge levels.
    When it is going to start printing it shuts off. No printing occurs.
    Also Feed Tray doesn't move.
  • joelrodz
    The printer is connected directly to the wall socket and it works fine. It turns on and performs its routing power up, with out any problems.
    It's only when I try to print that the printer turns off for no apparent reason.
  • joelrodz
    I downloaded the Epson Adjustment Program and noticed that there is a Fatal Error 61 (PW Sensor Error). So I opted to open my printer and there was ink all over! After cleaning what I could and cleaning the PW Sensor (Thanks to InkRepublic.com for the Tutorial) I restarted the printer. It still doesn't work!
    I just got the service manual and I'll see if I can access the Circuit Board to see if there's ink in it. Hopefully there is, so I can clean it and fix my Printer!
    I wouldn't have thought of short circuit problem, thanks once again Yboyandrei!
  • joelrodz
    joelrodz Aug 24, 2009
    New UPDATE - Aug 23
    Its hard to find an Epson repair store were I live. So I kept tinkering with the printer.
    I started disconnecting cables in order to see if the error stopped. After I disconnected the CN12 cable and started the printer... it started to WORK!
    Once I placed it back again... the error occurred. Figuring its either a bad FFC cable or a misplaced one, I opted to remove them all from the Main Board. I followed the natural bendings of the FFC cables. I reconnected them as I thought they should go.
    Would you believe the Error has STOPPED!
    Now... for the sad part! I can send the printer to print whatever I want... but nothing prints! It moves as if it where printing but no ink is ejected!
    Print heads are cleaned cause I already went through a set of cartridges cleaning them out.
    Maybe an inverted cable to the head?
  • Francis Mark Arango
    Francis Mark Arango May 11, 2010
    Have you check the Power Adapter?
Francis Mark Arango
    President:
  • 828 Answers
Here is my solution to your problem.
Power Failure is not reason here. I think you Epson have a problem inside the circuit board.
It has two output, the PRIMARY & SECONDARY Output, one of this are not function due to power or wattage failure.
I did encounter such problem but I open my printer and I see inside its nothing but the PCB Board have leak of one of my capacitor inside.
If this case is still comes out then better to check that with EPSON PRINTER Technician.
And about resetting EEPROM it useless.
At least this information give you such ideas why you have this kind of problem. Resolving such problem are not only on talk but let our hands do it also.
I tell you one way or another, careful of that maybe it has a short circuit. Good luck!
Posted on Aug 07, 2009
    Francis Mark Arango Aug 08, 2009
    your welcome my friend... Good luck!
Epson Stylus R1800 is not printing correctly. It is skipping spots leaving clear areas across the page. Changed all the cartridges.
your problem is not with the inks it is with the printhead... try running the maintenance and head cleaning... epson is notorious for print heads getting clogged!! good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Mar 31, 2010 | Epson Stylus Photo R1800 InkJet Printer
I want to print without the gloss optimizer but my
go to your print driver right click printer icon with mouse select property then click finishing turn off gloss. If this does not work then you can not over ride this feature
Oct 10, 2009 | Epson Stylus Photo R1800 InkJet Printer
Can the Epson Stylus Photo R1800 print on envelopes?
yes all sizes of envelopes using Microsoft word i have printed on 100mm square paper but only documents
Feb 20, 2009 | Epson Stylus Photo R1800 InkJet Printer
MacBook Pro Epson Print Driver Dilemma
your problem is about profiles. The gutenprint is the only way to print from intel to r1800, but this driver don't use the same ICC profiles. You have to use one of three solutions below:
1 the best, you have a profile calibrating device, you make a profile of your couple ink-paper and you convert your document into this ICC profile.
2 you convert your picture into your software in one of the Epson generic profiles (hey probably still are on your computer) and you print whithout color managment
3 (awful) you anticipate the color distorsion and you tune your picture to be bad on the screen but pretty good on paper.
Feb 03, 2009 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 Won't print anything but head utility
If you are using Mac, make sure you choose or add the correct R1800 printer ( USB or Firewire ) to the Printer list in order for the printer to response. Hope this will help
Oct 20, 2008 | Epson Stylus Photo R1800 InkJet Printer
Paper and ink lights blinking - no power light flashing at all - can't do anything on our Epson R1800 printer... can you suggest something to try? have been doing a lot of head cleaning due to bad nozzle...
Try doing a printer check by doing the steps below. If it doesnt work, then try to call the printer manufacturer for more advanced solutions or information
  1. turn off the printer and disconnect it from computer
  2. place a plain sheet of paper
  3. press and hold down the paper feed button, then press and release the power button. Continue holding down the paper button until you see the power light flashes
  4. if it prints a test page it is working fine, the problem might be the computer settings, printer settings, software or printer application, or cables, otherwise the problem is the printer itself
Oct 13, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson r1800 both light flashing
try taking out the inks you have installed make sure that you hear a click on each of the inks when you install them. If the issue persists the printer may not recognizing the inks you have installed.
Jun 02, 2008 | Epson Stylus Photo R1800 InkJet Printer
Image and text printed multiple times and are overlapping
Is the R1800 the only printer that you have on ythis mac?
If it is make sure it is directly connected to your mac via a USB or Firewire cable.
Trash epson folder from Mac HD-Library- Printers
Delete Epson printer utility from Mac HD- Application folder( if you have both delete both icon.
Under prnter setup utility delete the r1800 printer
Go to finder click on file the find, type com.apple.print, if it find anything drag it all on the trash, it will not disappear from the window ( the prefs and . cache files)
download the latest driver for your r1800 from epson website
epson12113.dmg - 10.3MB - posted on 12/20/
then reinstall it, after reinstalling try to readd th printer and make sure under print using it will say Epson SPR1800 series. If you see guten print/ that is a third party driver. dont use the gutenprint. then try to print, update me for the outcome
Apr 08, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson 1800 error message -9672
try using only one type of connection (USB or FireWire) see if that helps.
no known conflict for DivX for the printer, not sure for the mac though
Jan 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
628 people viewed this question
Ekse
Marvin
Marvin
