Question about Health & Beauty
Is it possible to get parts for a silverstar pride exterior lift? The wire connectors to be exact?
Posted by Charlene Phillips on
Tom Chichester
    Top Expert:
  • Health & Beauty Master
  • 55,958 Answers
The manufacturer/distributor should be able to advise you.
Posted on May 04, 2019
Lubrication for backpacker lift
try Permatex Silicone. I got some of the gel in a tube at a motorcycle shop. You can get spray can also. You can possibly pick it up at any automotive parts store
Oct 28, 2014 | Pride SilverStar Silver Star Backpacker...
HOW MANY OHMS SHOULD GO THRU PRIDE CELEBRITY X CONTROL ?
I have a Pride Legend XL. I tried to get the wiring diagram, but
Pride USA would not give it to me.
They told me to call the dealer instead. I had a problem with reverse throttle creep, where the brake would not engage and it kept rolling back on me.
Had to call the local dealer to do the intial trouble shooting
(who knew exactly what the problem was) to the forward reverse throttle control pot.. I was able to order the throttle pot and replace it myself.
The problem is that Pride uses some potted modules in the tiller
and the control area, although you can find pretty much
all the parts for Pride from monsterscooterparts.com,
they don't have the wiring diagram for mine either.
I am disappointed in Pride, who want to keep their
service manual with the wiring diagram a big secret from
the owners and only the dealers have it.
Oct 19, 2014 | Pride Health & Beauty
Pride backpacker plus lift breaks chain drive sprocket
That's Pride through and through - wretched, irrisponsible, greedy people.
I fear that you are stuck with insisting that the installer sort it out on pain of serious complaint through your Social Services, small claims court or both. You will not be outside the legal time limit for the period during which they are obliged to hold and supply appropriate parts. Good luck and give Pride hell, they really do deserve it. If you get annoyed with them on the Pride users blog they "withdraw your privileges". Unplug you and do not reply to emails - it happens all the time. Pride wants your money, not to be bothered by giving good service or loyalty.
Jun 08, 2014 | Pride Backpacker Plus Interior Lift...
Pride lift chair. Goes up, but will not down
There are only three wires for this. either the wire is broke, or the switch.
Oct 15, 2013 | Pride Mobility Products Casual CL30KD Lift...
Is it possible to get a copy of the repair manual for a 3 wheel Pride Legend XL scooter?
hi, it not a repair manual but a owners manual that is very helpful, the XL is my own personal favourite scooter but suffered from dodgy wiring and connectors otherwise it's a blast, I have reprogrammed the eGis controller to hit the max speed 10 mph.
Regards
GeWiz.
Mar 03, 2013 | Pride Health & Beauty
Battery won't charge, how do i take battery out of the THE PRIDE SONIC MOBILITY SCOOTER
Remove the seat by depressing a lever on the right side of the chair and pulling upward. there is a boot that covers the shaft of the seat rest. remove the boot and check for a pin with a ring on it. Once this is gone remove the shroud and you will find the batteries. Remove them with care and do a cursory check of all connectors. Some units have a 30 amp fuse on series with the batteries. Make sure the fuses aren't causing your trouble. Be certain to replace the batteries with the right polarity (positive to positive, etc...) Hope this helps.
Dec 27, 2010 | Pride Mobility Products Pride Mobility...
My Pride (Ameriglide) Backpacker Plus Lift Stops
If it's stopping in the same spot, it is a limit switch that isn't making contact with the lift sensor.
Here's a link to the wiring diagram that shows where the limit switches are.
ftp://webfiles.pridemobility.com/pdf_files/ipbs/domestic_us/silverstar/us_backpacker_plus_ipb.pdf
If it is tripping the circuit breaker, either your are trying to lift too heavy a weight, or the motor is pulling too much amperage due to previous abuse, or misuse. These are good lifts, and if you bought it new, then get ahold of your dealer and Pride will fix the problem. If you bought it used, they may have been using it to haul concrete...who knows?
Jun 13, 2009 | Ameriglide Double Entry Platform Lift for...
Switch Wireing Diagram
The motor operates on low voltage DC current Robert. You will have a negative and a positive, like a car. The center connector is a common, meaning that it will be connecting to the motor whenever you switch is activated to make it go, and the other two are positive and negative to control either up or down. These should be color coded red and black and will go to the outside connectors and the remaining wire will go to the center common connection. Hook it up and then test the chair lift button. If it doesn't lift, you need to reverse the two outside wires for correct polarity, or just use the switch controls opposite; up for down, down for up.
May 03, 2009 | Pride Mobility Products Casual CL20KD Lift...
Pride Lift Chair
Yes, jump, short, somehow bypass the switch and see if the chair moves. In 4 of 5 cases, I have had to replace the switch. Its the only part I carry with for "spares". Its an easy fix, and a lot cheaper than replacingt the whole hand control.
Feb 02, 2009 | Pride Mobility Products Casual CL30KD Lift...
Health & Beauty Logo
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
