SOURCE: AVIC-N2 AM fm radio XM radio Backup camera
Check the connections at your brain, you probably pull it loose when you removed the N1. Goodluck.
SOURCE: no am radio but fm works fine
I don't know why you need AM, but that's not the issue.
If you have FM and HEAR it ok, then everything is fine. You've hooked it up right.
Not being able to find AM, is in the new radio.
You need to look to see how to tune to AM.
Maybe the paperwork that came with it!
SOURCE: I HAVE A NEW PIONEER AVIC-710BT THE AM/FM WORKS
chances are, you hooked up the wrong blue wire... the power antenna wire (blue) is hooked up to the amp turn on wire... so while the radio is on its sending the signal to the amp to play and when the cd player is on it shut off... swap the blue wires and everything should be dandy...
