SOURCE: internal antenna
It sounds like the TV justs has a insufficient internal antenna system. If you can put an external antenna on this sytem do so just to test it.
SOURCE: trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
SOURCE: RCA HDTV, indoor antenna and Dish Receiver 311
I want to use two (2) 311 dish receivers with only 1 outside antenna.
SOURCE: I'm adding an over-the-air antenna to my DISH
You shouldn't need to. You should get your local channels from Dish on the low channel numbers, like 2 through 70.
