Question about Watches
Have a H band fitness watch, 1st 3 days sleep was accurate, now it only shows I slept 1 1/2 hrs last night shows i slept between 5:30 8 am, i was up at 5am
Posted by Linda Sturm on
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: Kenneth Cole Reaction band
Call 7298600 x 272 ask for a free pin for model rk 5033
Posted on Dec 08, 2007
Anonymous
  • 26 Answers
SOURCE: setting the date on my rolex president day/date watch
if all else fales, you are probably in need of a service.
Posted on Jan 03, 2009
Anonymous
  • 122 Answers
SOURCE: Previously accurate Seiko dive watch suddenly gaining 1-2 hrs/day
if your watch caliber is 7s26b(look at the case back plate)is a usual problem of those calibers!the hair spring stuck somehow and the watch runs!a seiko authorized sevice center can help you!dont let anybody else magician to ruin your watch!is a routine repair for someone with knowledge and support from seiko!
Posted on Jun 06, 2010
news775
Robin Bonathan
  • 699 Answers
SOURCE: Had rubber band fitted, instead of metal band,
ebay is your friend, look there and you should find one.
Please dont forget to vote this answer was helpful.
Many thanks
Posted on Mar 04, 2011
small6363
  • 18429 Answers
SOURCE: sportline watch #4823 band broke, need replacement, where?
try this link below
http://www.sportline.com/contact-us/contact-info.html
Posted on Oct 07, 2012
My Purchased Movado is unusual and the band has cutouts which have fallen apart .How can I fins a replacement band ? The numbers on the back of my watch are84-G2-1883 second line 7010784.Cant find th
That is a beautiful watch. There are a few used ones being sold now on eBay. I think you have 3 choices. The best would be to bring it to an official Movado dealer and ask if it's possible to replace the band. You could also get a routine service at the same time. If they don't have an identical band, then check out what other bands would fit, if any. Lastly, buy one of the used ones on eBay and hope for the best. Good luck. (Now that I think more about it, I've seen a few other internet shops that specialize in band replacement. They aren't very easy to find but it might be worth being persistent and making sure you've exhausted your options.)
Jan 06, 2015 | Movado Watches
Is it possible to replace the leather strap on my husbands Armani watch for one with links?
You would have to visit a retailer who sells watch bands and have them show you compatible bands. There are tons of universal ones, but it depends on the width of the connector where the leather band joins to the watch face, and if they have something that will fit that width. It can take them a few moments to change it out, after you've identified what fits.
Oct 18, 2013 | Giorgio Armani AR1029 Wrist Watch
I am wondering what is the bottom dial hand is for? The number on the case is JR-8675 then has BAW 250506 it has the main dial then three small dials one in the( day 45min )and one at (date15min) and one...
The subdial at 6 is ment to show you what part of the day it is. Example: if you are in Arctic, where the day or night can be a few months long, it would be very difficult to tell it's morning or evening, as the light conditions still the same in both cases. This small dial tells you exactly, because full day is divided to 24 hours and the hand of this subdial makes 1 full circle in 24 hrs.
Nov 16, 2010 | Fossil Watches
Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    How do you put the back, back onto this fs1? The band keeps getting in the way! Back came off easily enough, popped off after unscrewed. Band is still on watch, have tried to slide back into grooves but...
    You have to remove band in order to fit caseback back onto the watch. Insert pocket knife blade between band and case lug and pry inwards. This motion should release the band. It will be a lot more difficult to fit the band back on and you will probably need to buy springbar tool. Rate me plz.
    Mar 03, 2010 | Polar FS1 Unisex Heart Rate Monitor Watch
    Dec 11, 2009 | Seiko Divers SKXA35 Wrist Watch
    My grandson has had two Ironman watches with a
    good day,
    hope this link below will solve your problem.
    watches
    Feb 19, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
    Setting the date on my rolex president day/date watch
    Jan 01, 2009 | Rolex Day-Date President 118238 Wristwatch
    Aug 27, 2007 | Kenneth Cole RK5034 REACTION
    Watches Logo
    117 people viewed this question
    Top Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Bruce Robin
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
