Question about Health & Beauty
Recommended weight for 5'3" female - Health & Beauty
Posted by Karen Morrone on
joshua998
    Habit-Forming:
    New Friend:
  • 65 Answers
Using the BMI (Body Mass Index) method and to be in the "Healthy" range, 5'3" females should weight between 105lb and 140lb.
I'm sure Sir Mix-A-Lot would disagree though
Posted on May 03, 2019
How to control BP, female aged 90, with BP of 180 upper?
Not knowing you weight the easiest way is to loose weight. usually about 5 points per 10 pounds lost. Otherwise you will have to rely on prescription medications.
Nov 10, 2017 | Health & Beauty
What is the average weight for 5 foot 7 inches?
Female Ideal Weight - Above Average Height The average height of a woman in the US is 5-foot-4. When considering the weight and height ratio, a 5-foot-5 woman should weigh between 113 and 138, 5-foot-6 between 117 and 143 and 5-foot-7 between 122 and 149. The weight and height ratios continue to increase at approximately 4.5 pounds at the low end and 5.5 pounds at the high end of the range, per inch of height. A 6-foot-tall woman's ideal weight range is 144 to 176 pounds and a 7-foot-tall woman's range is 198 to 242 pounds. Male Ideal Weight -- Under 6 Feet Tall Men have an ideal weight range similar to that of women, but their weights are higher per inch. A man who is 5 feet 11 inches tall has an ideal weight range of 155 to 189 pounds, which is significantly higher than the 140- to 171-pound range for women. Men under 6 feet tall can determine their ideal weight without consulting a height-to-weight ratio table by starting at 5-foot-11 and a weight of 155 to 189 pounds. Simply subtract 5 to 6 pounds per inch from the low of 155 pounds, and 6 to 7 pounds per inch from the high of 189 pounds. Thus, a 5-foot-5 man has a range of 122 to 150 pounds and a 5-foot-tall man has an ideal weight range between 95 and 117 pounds. Are There Ideal Weight and Height Ratios LIVESTRONG COM
Jul 09, 2014 | Health & Beauty
Recommended tyre pressure
The required tyre pressure is established by the amount of load or weight that the tyre is carrying. Over or under inflation can cause excessive tire tread wear. The recommended pressures for your tyres are shown in raised lettering on the sidewall of the tyres.
Depending on what you are towing, you will know how much additional weight is being placed on the cars rear tyres, and you can adjust the pressure accordingly.
Personally, When I am towing, I increase the tire pressures by about 5 psi just to reduce sidewall flexing and create a more stable towing package.
Hope this helps.
Apr 03, 2014 | 2005 Chrysler Voyager
Heavier Oil weight for Dodge Caravan
10-30 would be better,the 5-20 is really to thin to work well,the factory used it to get a bit better fuel mileage.Your Dodge probably just needs a a set of valve seals,only a couple hour job.
Jan 10, 2014 | 2007 Dodge Grand Caravan SXT Minivan
Have 2006 GMC Canyon Reg Cab, 5 cylinder. Will be traveling across country with approx 1000 lbs in bed. Tires are Hankook listed at 1874 lbs 44psi max. Recommended tire pressure on door is 33psi cold. What...
The load rating on the tire is per tire.33 psi will be fine,but for some added fuel savings I would air them up to the 44 psi in the rear.Don't for get to let them down when you remove your load or you will get center tire ware.
Apr 21, 2011 | GMC Canyon Cars & Trucks
Is there a difference in the weights of motor oil 10/30 and 10/40?
Yes. 10-w30 will act like a 10 weight oil when cold and a 30 weight oil when hot. 10-w30 will act like ten weight when cold, but like (thicker) 40 weight oil when hot. Your profile only says Cadillac and doesn't say model or year, but most cars since the early- mid 80's use 5-w30. Always use the oil weight recommended in your owners manual. If you are unsure call the dealer and they will tell you what is right for your car.
Mar 08, 2011 | Cadillac DeVille Cars & Trucks
What type of oil do i use
In winter I use 5 w 30 multi weight oil and in summer I switch to 10 w 30 multi weight oil.
If you still have the users manual there will be a recommended oil but I don't think you can go wrong with the above listed suggestion.
Jan 02, 2011 | 2001 Chevrolet Blazer
I am depressed about my weight and i have low self-esteem i don't know what i can do to keep my husband interested
It doesn't matter which way it goes.Male to female/female to male.A nice smile and a compliment to the other person can make them feel fantastic.A hug doesn't hurt either.
Apr 22, 2010 | Bodycraft Exercise & Fitness
What does the Bone Mass number mean on my digital scale?
I found this from another posting. Hope it helps.
FEMALES: age 20-29 normal= 6.2-7%
FEMALES: age 30-39 normal= 6-6.8%
FEMALES: age 40-49 normal= 5.6-6.4%
FEMALES: age 50-59 normal= 5.2-6%
FEMALES: age 60-69 normal= 4.9-5.7%
sorry no listings over age 69
My only thing now, is what it means if I am below the range.
Nov 14, 2009 | Health & Beauty
Health & Beauty Logo
20 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
