Adobe Photoshop 7.0 for PC Logo
Posted on Aug 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flash player will not install using the activex control
I have windows xp and cannot install flash player
Anonymous
Level 2:
  • Expert 290 Answers
  • Posted on Aug 07, 2009
Anonymous
Expert
Level 2:
Answers
290
Questions
0
Helped
92282
Points
892
What does windows xp prompt?
i suggest that you try installing with active x flash player and a flash player for the web. use the latest version. Adobe Flash player is the recommended flash player for windows xp platform. pm me if you still have problems. Thank you.
Try to install adobe flash player i get a message saying cannot contact reliable source. what does this mean?
This is the solution:
http://www.adobe.com/support/flashplayer/downloads.html#fp10.3
You must installed the Download the Windows Flash Player 11.6 ActiveX control content debugger (for IE)
I try it and it works.
Ever since i sinked a google account to you tube i nolonger get video only audio i've tried un-installing flash player and re-installing it but nothing went to utube site, followed there link in help...
Try the following: 1. Temporarilydisable popup blocking software installed on your computer to test. 2. AllowYouTube.com as a trusted site in your Firewall software. 3. Ensureother applications like Quicktime, iTunes, Real Player, or Windows Media Playeraren't set as the default streaming application, as this might affect the videoplayer. 4. Make sureyour computer is set up properly for Flash:Confirm you allow the websiteFlash content to play on your system
View the settings manager for your Flash Player installation. 1. Right-click(Windows) on any Flash content. 2. Select" Global Settings." 3. Select"Global Storage Settings panel." The Adobe Flash Player Settings Manager should display. 4. Select"Allow third-party Flash content to store data on your computer." 5. Restartyour browser and try playing an embedded video.
  • To view or change the privacy settings for websites you have already visited, use the Website Privacy Settings panel.
  • To view, change or delete the storage settings for websites you have already visited, use the Website Storage Settings panel.
Check the browser security level
Make sure that the security level is not set to High or to acustom level that doesn't allow viewing of ActiveX controls. Typically, thedefault security level (medium) allows you to view Flash content. For a customlevel, ensure that both Download Signed ActiveX Controls and Run ActiveXControls And Plug-ins are set to Prompt. For example, in Internet Explorer: 1. ChooseTools > Internet Options 2. Clickthe Security tab 3. ClickDefault Level, or click Custom Level
  • Find the section ActiveX Controls And Plug-in
  • Set Download Signed ActiveX Controls to Prompt
  • Set Run ActiveX Controls And Plug-ins to Prompt
If I could be of furtherassistance, let me know. If this helps or solves the issue, please rate itand give a testimonial for my response.
2answers
Can't dowm load flash player
If you have problems installing Adobe Flash Player2.gif, follow the troubleshooting steps below. If one step does not correct the problem, move on to the next step. After each step, you may want to restart your machine to ensure that your changes take effect before moving on to the next step.
Uninstall all previous versions
Before you install Flash Player for any Windows browser, uninstall all previous versions. For instructions on removing the player, please see "How to uninstall the Adobe Flash2.gif Player plug-in and ActiveX control"
at this link...
http://kb2.adobe.com/cps/141/tn_14157.html
Note:All applications must be closed before you run the Flash Player uninstaller. Quit all running applications, including all Internet Explorer or other browser windows, and all Instant Messenger clients. Check the Windows system tray carefully to make certain no applications which might possibly use Flash Player are still in memory.
After you have removed previous versions, you are ready to download and/or install Flash Player.
2. Download Adobe Flash Player Flash Player is available for download from the Adobe Flash Player Download Center.
3. Troubleshoot Adobe Flash Player for Internet Explorer Before installing Flash Player, please check the following browser settings:
Internet Explorer ActiveX settings Browser security settings should be chosen by you or by your system administrator. For single users who do not have an administrator, the Medium: Default Level allows you to view Flash content. For any Custom Level, ensure that both the "Download Signed ActiveX controls" and "Run ActiveX controls and plug-ins" options are set to "Prompt".
To change your security level:
  1. Open Internet Explorer.
  2. Choose Tools > Internet Options.
  3. Select the Security tab.
  4. Select Custom Level.
  5. Find the section "ActiveX controls and plug-ins".
  6. Set ' Download Signed ActiveX Controls' to Prompt.
  7. Set 'Run ActiveX Controls And Plug-ins' to Prompt.
If you are having trouble installing, make sure that your Internet Explorer security level is not set to High or to a custom level that does not allow viewing of ActiveX controls.
Windows Vista installation failure On some Windows Vista systems Flash Player may be installed, but will not display Flash content. In some cases updating to the latest Flash Player using the included utility can correct the User Account Control settings that cause this problem.
To run the utility, find your installed Flash folder:
  • Right-click C:\Windows\System32\Macromed\Flash\FlashUtil9d.exe
    The letter changes with each Flash version, so may be "FlashUtilb.exe" or "FlashUtile.exe"
  • Select "Run as Administrator"
  • Follow the steps to complete the Flash Player installation
  • Restart your computer
Computer user permissions User permissions determine whether or not you are allowed to install ActiveX controls or plug-ins. If you don't have Administrator access to Windows NT, 2000, XP, or Vista you may not be able to install Flash Player successfully. Administrative privileges are required for the Windows system registry and for the C:\WINDOWS\system32\Macromed\Flash folder
2helpful
I can't download adobe flash player, I think it has something to do with my flash card witch is not working either I downloaded various things from toshiba site BIOS, Utilities, and a flash card compatible...
If you have problems installing Adobe Flash Player, follow the troubleshooting steps below. If one step does not correct the problem, move on to the next step. After each step, you may want to restart your machine to ensure that your changes take effect before moving on to the next step.
Before you install Flash Player for any Windows browser, uninstall all previous versions. For instructions on removing the player, please see "How to uninstall the Adobe Flash Player plug-in and ActiveX control"
at this link...
Computer user permissions User permissions determine whether or not you are allowed to install ActiveX controls or plug-ins. If you don't have Administrator access to Windows NT, 2000, XP, or Vista you may not be able to install Flash Player successfully. Administrative privileges are required for the Windows system registry and for the C:\WINDOWS\system32\Macromed\Flash folder.
1helpful
Can't get Adobe Flash Player 9 ActiveX.exe to download.
Flash player 9 is actually not the latest version. If you want to install the latest version which is version 10, follow the steps below:
a. Download the most recent Flash Player uninstaller to your desktop from the TechNote below. Please read the instructions in the TechNote before running the uninstaller.
http://www.adobe.com/go/tn_14157
b. Quit ALL running applications, including all Internet Explorer windows, other browser windows, AOL Instant Messenger, Yahoo Messenger, MSN Messenger or other messengers. Check the Windows system tray carefully to make certain no applications which might possibly use Flash Player is still in memory.
c. Open the following folder: C:\WINDOWS\system32\Macromed\Flash
d. Run Flash Player uninstaller.
e. Check if there are files left in the folder: C:\WINDOWS\system32\Macromed\Flash. If there are any files left inside the folder, delete the files.
f. Download and install the latest Flash player at:
Flash Player 10,0,12,36 Active X (for Internet explorer)
http://tinyurl.com/67twte
Flash Player 10,0,12,36 Plug-In (for Firefox,Netscape,Safari,Chrome,etc)
http://tinyurl.com/8nz9s
1helpful
2answers
Flash Player 10
Is your PC running with Win XP with Service Pack 2 or higher? Which browser do you use ( Internet explorer or Mozilla Firefox)
Check out the Add Remove Panel for the Latest installation of
1. Adobe Flash Player ActiveX
2. Adobe Flash Player Plugin
3. Adove Shockwave Player 11
Download it from this weblink: Flash Player http://labs.adobe.com/downloads/flashplayer10_ax.html
Also check this update for Microsoft: http://support.microsoft.com/kb/912945
Let me know the exact error message coming up, to narrow down problem. For more help you can email at techin.scott at gmail.
Regards,
Ellin
Flash 9 freezes after 1st. video plays on The Fan.
Lets Start from here:
Before you install Shockwave Player for any Windows browser, uninstall all previous versions.
In order to remove the Shockwave player, simply use the file UNWISE.EXE located in C:\WINDOWS\system32\Adobe\Shockwave 11. Windows users can also use the Add/Remove programs located in the Windows control panel. This will remove the Shockwave 10 player
For the Shockwave 8 and 8.5 there is an uninstaller available from the Web Players page.
Note: All applications must be closed before you run the Shockwave Player uninstaller. Quit all running applications, including all Internet Explorer or other browser windows, and all Instant Messenger clients. Check the Windows system tray carefully to make certain no applications which might possibly use Shockwave Player are still in memory.
After you have removed previous versions, you are ready to download and/or install Shockwave Player.
Before installing Shockwave Player, please check the following browser settings:
Browser security settings should be chosen by you or by your system administrator. For single users who do not have an administrator, the Medium: Default Level allows you to view Shockwave content. For any Custom Level, ensure that both the "Download Signed ActiveX controls" and "Run ActiveX controls and plug-ins" options are set to "Prompt".
To change security level in Internet Explorer:
User permissions determine whether or not you are allowed to install ActiveX controls or plug-ins. If you don't have Administrator access to Windows XP SP2, or Vista you may not be able to install Shockwave Player successfully. Administrative privileges are required for the Windows system registry and for the C:\WINDOWS\system32\Adobe\Shockwave folder.
If the ActiveX Control for Shockwave Player fails to install, download the executable installer.
If the information above has not resolved the issue, download the executable Shockwave Player installer here:
* Download and latest Shockwave Player Installer.
Save this installer to your desktop, close out all applications, and run the installer. This may help if you are having trouble with the ActiveX installation from Adobe.com. To confirm that Shockwave Player has installed successfully, please click here. The two movies will show if you have Flash and Shockwave Players installed. The version numbers of the both Players will be displayed in the test movie.
Adobe
First of all check if you are in Admin mode.If so
When Internet Explorer 5 on Windows encounters a request from a page to download a new ActiveX control, an option is provided to allow the user to prevent the specified ActiveX control from ever installing in the future. If this option, called Install on Demand, is selected when you encounter Flash Player ActiveX controls, future installation attempts of these controls will fail.
If you are unable to install Flash Player due to this feature, first run an executable that rectifies the problem and then install the Flash Player.
Is it enough?
Please rate it
Top Adobe Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
